misfire
I have a 65 chevy c20 and I have a misfire any suggestions on what I should look for? or where to start.
Re: misfire
need more info
Post Whore
![]() Join Date: Mar 2013
Re: misfire
Like said, and is it an inline 6 or V8? What type of misfire? Is it popping....or just a slight poof, or really bad popping? We need more info cause it could range from ignition to compression, or valves springs or valves...so if you can post a video that would be cool also! We will do the best we can to help! Lotta great people on here!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Re: misfire
V8 327
Re: misfire
if its at idle it's great. but as soon as I give it gas it has a loud pop.
Post Whore
Re: misfire
Probably a backfire through the carb...might be running it to lean. try adjusting the idle mixture on the carb and see what happens.
Re: misfire
how do I post a picture?
Post Whore
Re: misfire
When you post a reply go to the "Manage attachments" option and you can post a picture.
Re: misfire
video sorry
Post Whore
Re: misfire
You have to post it on youtube.....then transfer the link to here.
Re: misfire
Has any work been done recently?
Are the #5 and #7 plug wires too close/touching?
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel |
Re: misfire
I recently put new points on
#13 |
Re: misfire
Bingo.....your a man of few words......how did you set the points
#14 |
Re: misfire
I removed the distributor cap. took off the old points since they had been burnt. placed the new ones on and gave them a gap of a match box.
#15 |
Re: misfire
this morning I checked the spark plugs and cleaned them out. I started the truck and noticed that some gas had been leaking from the bottom of the carb. after I turned the truck on it turned white.
#16 |
Post Whore
Re: misfire
Usually a leak from the carb will cause a vacuum leak, causing stuttering, hesitation, or stumbling.
#17 |
Re: misfire
but that would not cause the misfire then
#18 |
Post Whore
Re: misfire
No, it shouldn't. Causes of misfires are bad plugs, even the spark plug wires can cause a misfire if the covering is stripped or worn in places, sticky valves, weak valve springs, burnt points(usually it won't even start), a flat cam could be a possibility, did you check your compression? Burnt valves or worn valves will cause a misfire or constant popping. You can check if you have issues with the head by compression; if all is even then you might have weak springs or ignition issues, if your compression is much lower in some cylinders then you have valve issues or piston ring issues.
#19 |
Re: misfire
Your loud pop could be a lack of timing.
What's your initial timing set at? |
#20 |
Re: misfire
cool all this info will help
#21 |
Re: misfire
Could also be a problem with the brain of the engine.
Wore out lobe on the cam shaft. |
#22 |
Re: misfire
#23 |
Re: misfire
I would also go back and set your points properly....gap...dwell...then timing and carb adjustment
#24 |
Re: misfire
I will be setting the timing and will adjust the points on Monday will keep you updated with what's going on.
#25 |
Re: misfire
set points first, point dwell affects timing, timing doesn't affect dwell.
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
