![]() Join Date: Aug 2007
Need Steering Column
Anyone had any experience with Classic Performance Products and their steering column? What about any other vendors for this item?
![]() Robert 71 Chevy SWB |
Re: Need Steering Column
Yes, I had one in my truck, it was a POS. Rather than try to sell it, it was such a POS, I tossed it in the trash. There's also a thread somewhere about the tilt ball failing and causing full steering loss.
Mark 71 C10 Cheyenne 12 Aprilia RSV4 |
I had one, took it back out after reading about what a POS they are. Swapped in a Flaming River column.
CPP looked like a repro of stock, and fit well. I had issues with turn signal cam----could not get the springs to stay put and work to cancel the signal. Then I read an article on here about how bad they are made. I still have it in a box because I paid too much to throw it out.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
ididit columns are the best !!!
![]() Join Date: Mar 2012
contact Kevsclassic on here , he rebuilds factory ones i got one from him and it is awesome and OEM correct. I think it cost me 475.00 if i rememeber right plus shipping
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
X2 Kevin is the man for steering columns!
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
