10-31-2013, 08:23 PM | #1 |
Dome lamp without door jamb switches?
On a 70, just as the post title implies I was preparing to start on the rockers and cab work on one of my 70 trucks and after I removed the door and started to beat around on the outer rocker just to see where the stability is ,I noticed where the pinch weld is/was that I had three wire. One is for gas gauge. The yellow and white two together [I think] is for the dome lamp, That I did not even know I had. How or why would it have a dome lamp without door jamb switches in the door pillars? When I put it back together wouldn't I hook up some door switches and make [courtesy] lamp that work when the door open? Jim
10-31-2013, 08:29 PM | #2 |
Re: Dome lamp without door jamb switches?
or hook up the lamp to work from it's switch.
10-31-2013, 08:39 PM | #3 |
The switches were only included with the CST trim level in 1970 or as option C80 according to info I have. The dome light should go on when the headlight is rotated fully clockwise (I think it's clockwise).
10-31-2013, 09:44 PM | #4 |
My 70 has a dome lamp, but no door switches. It only works when you rotate the headlight knob.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
10-31-2013, 10:18 PM | #5 |
Hey guys,
First off I have to turn my headlight switch counter-clockwise all the way to turn on the dome light. You should feel it kind of snap into position. I also have factory holes about midlevel on the rear of the door frame for dome light buttons. The way the light is wired it just needs a ground(anywhere) to light the dome. When you open the door, the button is designed to ground the white wire and complete the circuit.The door buttons are tied into the ground(white) wire without breaking the original connection. Mine(1967 C10) doesn't come with the door buttons originally, but it's pretty obvious some of them did, since it comes with the holes already. The Orange wire(which may have faded to yellow) is a power wire that goes uninterrupted to the dome light. You should also have a hole on the passenger side door frame as well. You only need to run another ground wire over there to add another grounding button. I bought a couple of buttons at cpa for about $5 each, iirc. I haven't installed them yet because it a pita to get to the hole on the driver's side with the gas tank installed. I'll get around to it when I replace my grommet for the gas fill tube in the near future. Hope this helps, Curt
If I have to be on 4 wheels, It has to be a classic Chevy 1967 c10 Longbed (Hawghauler/Icy weather transport) 2003 BMW K1200GT (Rain bike) 2007 Softail Deuce (Sun bike) 2009 Ultra Classic Electra Glide (Everything else bike) |
10-31-2013, 10:49 PM | #6 |
My 72 cheyenne has the pin switches in the cab at the front near the hinges. Only higher trim level teucks had switches. All of the cabs i have looked at had a flat spot where the switch goes. The hole just has to be drilled and wire run. The pin switches and wire could be added to any truck. As stated above tou just need the wire for the ground. I believe i have seen the harness and switches at Classic Parts and LMC. I an sure ither vendors have them as well.
10-31-2013, 10:56 PM | #7 | |
11-01-2013, 06:51 AM | #8 |
Yes, there is an indented place on both side where the door jamb switch would be if were installed. I did not inspect it closely enough to see if there is a center punch mark as there is on similar thing of this nature on newer trucks and cars from the General. Jim
11-02-2013, 10:19 AM | #9 |
Mid and upper level trucks had jamb switches and base trim didn't.If the truck came with stainless window trim it came with door jamb switches. The base trim trucks you need to twist the headlight switch to the left to get the light on,which you can do on the other trucks,too
67-70 C/10/20/30 and 71/72 Custom/10/20/30 = no jamb switch
01-22-2014, 06:40 PM | #10 |
Yes , it all makes sense, but i can't find a vendor that sells the switches!?! Isn't it amazing what would pass as optional only a few years ago! Anyone know a vendor? Seems like everyone would want this easy option. Erik
01-22-2014, 06:52 PM | #11 |
I was told once that the first Mustang had over a 1000 options, and that if you ordered the base model it came with no rims.........or so my high school shop teacher told us
_________________________________ 62 Impala 70 C-10 LWB 71 K-10 SWB 85 C-10 LWB==SOLD 01 2500 HD Members Met......2003Silverado (Dave) |
01-22-2014, 08:00 PM | #12 |
Where did they put the tires?
01-22-2014, 08:14 PM | #13 |
I just installed door switches on my 72 in the factory position. Here are a couple of pics. I picked the switches up at Autozone for about $5 each.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
01-22-2014, 08:21 PM | #14 |
for my '68 I like just having a on/off manual switch on dash near drivers door - using ground (white) wire. that way I can work on truck interior, etc and not have to try to keep door jamb switch pushed in with tape, or whatever. if I really finish the truck, unless I sell it, will likely hook up door jamb switches.
01-22-2014, 08:22 PM | #15 | |
The term rim drives me crazy! Rim From Wikipedia, the free encyclopedia An aluminum alloy wheel The rim is the "outer edge of a wheel, holding the tire".[1] It makes up the outer circular design of the wheel on which the inside edge of the tire is mounted on vehicles such as automobiles. Ok..............I feel better.
01-22-2014, 08:40 PM | #16 |
found a door switch at classic parts for 3.95 all metal , don't know if it's brass Turns out I answered my own question. ! Erik
01-22-2014, 10:13 PM | #17 |
A dome lamp bypass might be nice to have like the ones in the 99 and newer Chevy and GMC trucks where you can decide if you want to use them or turn them off such as in the case of an open door during a working time. Just anther one of those things to make you go huh?
01-23-2014, 02:19 AM | #18 | |
01-23-2014, 03:58 AM | #19 |
I picked up a full wire harness for "courtesy" lights that go under the dash. I got them out of a newer truck with switches, wire, bulbs and all. I don't think I paid much if anything for it. Many times at the yard when you buy a lot of stuff they won't even charge you of the little stuff. I don't have them put in yet, because that will wait til I'm back in the states and retired.
01-23-2014, 05:12 AM | #20 |
My 70 does not have door switches either. Dome light is turned on and off with the headlight switch
01-23-2014, 11:47 AM | #21 |
I ordered my door switches, I gotta have this option. it's such an easy addition too!
01-23-2014, 12:39 PM | #22 |
Sorry for the dumb question here...but where do the wires for the switches pass through?
I have the courtesy light kit sitting on my shelf but was reluctant to start drilling holes without asking first! |
01-24-2014, 06:47 AM | #23 |
Measure the size of the threaded portion on the switches, use a sharp punch to make a small dimple to ensure the hole stays where you want it. You may even drill a small pilot hole too. To ensure that you have the right sized hole, drill a hole in a scrap piece of sheet metal and check for proper fit. To route the wire, go up under the dash on the kick panels select a location so that the wire won't interfere with the vent door operation. Drill a hole sized to allow the two wires to go through and be secured with a rubber grommet. After all that, you just need to feed the wire through the hole and fish it through the hole in the door jamb. A technique to use is to feed a length of small wire throgh the jamb hole (I like a single strand of phone wire for this) and tie it to the end of the harness wire, and then just carefully pull it through the jamb hole, hook up your switch, screw it in, take out the slack (gently, not too tight), mount your courtesy lights (if it applys), and hook the harness up to the fuse box.
For the dome light to work on these switch, you'd have to hook the lead wire to this circuit (if I remember right, it's the orange and white one that runs down under the sill plate on the drivers side) I know this is kinda wordy but that's it Last edited by 70Custom10Nut; 01-24-2014 at 06:52 AM. Reason: grammer/spelling |
01-24-2014, 07:44 AM | #24 | |
1969 Custom 30 wrecker
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
01-25-2014, 12:40 AM | #25 | |
