Gas Tank Question
How do I know which gas tank I need ,EEC or no EEC ,has 2 gas lines going through the cab floor if that matters ?
Re: Gas Tank Question
Anyone ,I need to order a tank soon ?
![]() Join Date: Jul 2001
John, what year truck do you have? The EEC tanks started in '71, not sure just when, early or late build date. My '71 has the EEC tank. On the passenger side is a tube or hose that comes off the tank and goes up inside the rear passenger pillar behind the door. Be sure you get a vented style cap to go with it. Hope that is some help.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Mine is a 72 ,and thankyou , it helps a lot .
my 72 is a standard tank and only had one fuel line on it.
I'm no expert but pretty sure the EEC tanks started in '71 and an original '72 1/2 ton would have the EEC tank. Is your truck 1/2 or 3/4 ton? 3/4 ton trucks did not have the EEC tanks until later into the square body era.
Ironhorse ,you are correct as the guys at Southern Kentucky Classics told me the same thing when I called to place my order today .The shop will be getting some stuff to play with next week.
Thanks again John |
flashed, are you doing a 1/2 ton or 3/4 ton, not sure but just curious. I like'm all, 67-72 body style is the best GM ever designed. Think in the last 5 years I've only seen one long step-side but many, many short steppers, short wides and long wides. 4x4's seem rather un-common here but do see them from time to time. Think there are 6 or 7 including mine here in town, SWB and LWB mix.
The one in the bodyshop is shortbed 1/2 ton ,Im also playing with a 72 1 ton flat bed dually with BuddyBuckets and Im daily driving my barnfind 74 shortbed stepside with 60,000 original miles that I watched for 20 years before getting to buy it .I know of many others but they are not YET for sale ,so I keep on watching them.
