Old 10-31-2013, 10:32 PM   #1
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
Gauge Rage
Ever since I got the 68 truck of mine running I have had problems with the fuel gauge . After I got the truck running the gas tank had to be replaced because it was rusty . So I got a used gas tank and a brand new sending unit from LMC. My mechanic installed it in there for me since he was already rebuilding my carburetor and he said that it worked fine. But after I picked up the truck I discovered that the fuel gauge was not working so I checked the sending unit and found the float had sunk . LMC sent me a new float and when I installed it the gage still would not work . So LMC send me a new sending unit and I installed it today but when I install it it does not work either . With the key switch in the on position and the sending unit hooked up to power you can ground it by hand and it will work . But for some reason the sending unit only works if you hold it in your hand and ground it while it is hooked up . As long is the sending unit is installed in the gas tank the gage will not move unless you almost fill it up and then it only registers a quarter of a tank or so. Clearly there is some frustrating issue going on here but I cannot figure it out .
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 11-01-2013, 04:23 PM   #2
HIGHWAY BY THE SEA
Re: Gauge Rage
So so no one has any idea why my sending unit only works correctly when I hold it in my hand ? I was thinking there might be a bind of some type inside the gas tank but I cannot imagine why because it is in practically new condition.
Old 11-01-2013, 04:56 PM   #3
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: Gauge Rage
Your tank isn't grounding for some reason
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 11-01-2013, 05:11 PM   #4
ddman6
ddman6's Avatar
Re: Gauge Rage
Try to ground the sender with a wire connected to a known good ground source. It is possible that you are missing some grounding straps and your cab has a poor ground.
Dewayne
ddman6 is offline   Reply With Quote
Old 11-01-2013, 05:45 PM   #5
HIGHWAY BY THE SEA
Re: Gauge Rage
For some mysterious reason it will not ground like that . if I hold the sender in my hand with the pink wire attached to it and then touch the gas tank it will ground, but you install it inside the tank it will not .
Old 11-01-2013, 05:45 PM   #6
Tinkermc
Re: Gauge Rage
I must agree you have a ground problem.
Tinkermc is offline   Reply With Quote
Old 11-01-2013, 06:09 PM   #7
Lee H
Lee H's Avatar
Re: Gauge Rage
You should have cab to engine and cab to frame grounds, are they intact and nice and cleanly grounded?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 11-01-2013, 08:23 PM   #8
HIGHWAY BY THE SEA
Re: Gauge Rage
As best I can tell the tank is grounded. The gauge registers correctly when I touch the sender to the tank when I am holding the sender. But NOT with the sender installed in the tank. Weird mystery! And frustrating. I have to keep a gallon can of gas in the truck in case I run out.
Old 11-01-2013, 10:31 PM   #9
hayhauler71
hayhauler71's Avatar
Re: Gauge Rage
This may seam stupid but my new sender float arm was bent wrong had to dump 10 gallons in tank then adjust arm to 1/2 on gauge. If your gauge works grounding it to the tank your tank is grounded and not a problem
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 11-02-2013, 11:39 AM   #10
ddman6
ddman6's Avatar
Re: Gauge Rage
You might also check for interference inside the tank.
Old 11-02-2013, 11:50 AM   #11
68gmsee
Active Member
68gmsee's Avatar
Re: Gauge Rage
This is what I was going to mention also. I got one from LMC many years ago that didn't work and found the float was touching the tank when installed in the tank. I had to bend it in such a way so that it would move freely without binding.
On another occasion, I got a sending unit that had defective windings and only worked in one position. When you have yours out, don't just ground it but using a volt/ohm meter, see if it goes up and down in resistance with the meter in ohmsX1 setting.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 11-02-2013, 02:18 PM   #12
HIGHWAY BY THE SEA
Re: Gauge Rage
I no longer think it is a ground issue. When I ground the sender with a second source it still does nothing in the tank. And when filled up the gauge goes to 1/4. So it must be an internal logistical problem. Am taking it to a friend who has ohm testing equipment tomorrow.
Old 11-02-2013, 07:05 PM   #13
68gmsee
Active Member
68gmsee's Avatar
Re: Gauge Rage
If you're sure it's not binding, remove it from the tank to make sure the resistance changes through the whole range.
btw: you might want to invest in a volt/ohm meter. I can't begin to count the times I've used it on both of my trucks to check voltage and resistance when encountering an electrical problem. They're fairly cheap - ranging in price form $15 to $30 for a reasonable one.
06 Trailblazer
Old 11-03-2013, 10:09 AM   #14
Andy4639
Old member
Andy4639's Avatar
Wink Re: Gauge Rage
Hook the gauge up and put a jumper ground from tank to sendor. See if it works. Then move the float up and down to see if it changes on the dash with your hand moving it. If so then it's hanging up inside the tank.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-04-2013, 02:00 AM   #15
HIGHWAY BY THE SEA
Re: Gauge Rage
Mystery solved. I took this to my friends house today and we removed the sending unit and he tied a string to the float rod . The sending unit was held in place by hand and he pulled on the string . It was then that we realized that the float was indeed tapping against the side of the tank causing the float rod to stop short. We bent the sending unit float rod so this would no longer happen, now the gauge does work . Next up I have to make sure it is registering correctly because I put 10 gallons of gas in there and it only registered 3/8 full. Figured it would be more than that. Now I need to caution anyone who buys a sending unit from LMC. BOTH sending units that I received from them had this same problem . So these things need to be adjusted because they are apparently made incorrectly .
Old 11-04-2013, 02:10 AM   #16
ddman6
ddman6's Avatar
Re: Gauge Rage
Way to go. Congrats on figuring it out. It is good to know that these sending units can have this problem. I've had multiple go bad over the years and have considered lmc for replacement. Thanks for the info.
