K10 Blazer HELP
I bought a 1983 GMC Fullsize Jimmy. I knew it was a rust bucket when I bought it, I have known the guy I got it from since I was in diapers and he had it since new. It has a snow plow on it and basically he sold me the plow and gave me the truck. Well upon lowering the tailgate recently it fell off in my hands and the floor is very rotten. I bought a cab from an 86 Chevy pickup. and I want to build a flatbed. Any advice on pulling the jimmy body off, putting on the pick up cab and best way to build a wooden flatbed. I'm not a mechanic or a body man, my father has a background in mechanics so he is going to help me but we still would like some advice.
Re: K10 Blazer HELP
hope you have a pile of scrap metal and some fabrication skills. I did a s10 onto a k5 frame but I think the rear cab mounts are the only ones you have to build.
1985 ![]() |
Re: K10 Blazer HELP
I usually have some stuff laying around and I have a welder so I'm sure I can get something to work in the way of cab mounts.
Second Chance Program
Re: K10 Blazer HELP
Search. And review rust repair threads. Buy patch panels from classicparts or LMCtruck.com.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
Re: K10 Blazer HELP
There isn't any rust on the new cab. The current body is beyond repair. The entire floor would need replaced and there is nothing left to weld to. The front fenders will need replaced, the back fenders need replaced, the tailgate hinges are rusted off, the body is trashed. It lived its whole life as a snow pusher and the salt ate the body apart, the frame however is fine.
Re: K10 Blazer HELP
Putting a cab on the frame shouldn't be that hard its been done a lot.And with the flat bed it would only be like 4 foot long.Something like this http://www.cardomain.com/ride/218690...vrolet-blazer/
Re: K10 Blazer HELP
Yes - keep in mind the Blazer/Jimmy is shorter than a shortbox pickup, so you'll have to fab cab mounts and you'll have a super-shorty flatbed.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Re: K10 Blazer HELP
The front cab mounts are the same on blazers and pick ups. There were a few frame changes on blazers. 73-77 was different from 78-91. 87-91 floor pans were different from 78-86. on the blazers. What year is the cab your using?
Re: K10 Blazer HELP
Its an 83 blazer and I'm using an 86 cab
Re: K10 Blazer HELP
Re: K10 Blazer HELP
Is the cab from a 4x4 truck?If not you will need the high hump trans tunnel out of one.
Re: K10 Blazer HELP
I do have a cab from a 4x4 but just out of curiosity how big of job would that end up being to do? I have a 2wd cab laying in the grove I had thought of using before I ended up buying the 4x4 cab
#13 | |
Re: K10 Blazer HELP
If I were you I would find a rear cab mount crossmember to modify/bolt/weld into your blazer frame. That would simplify the swap. This swap is somewhat common and pretty straight forward. There is at least one build thread on here. I'll see if I can find it. On the flat bed, I would build it to bolt to the frame with a metal structure and use wood for the floor only You might try actually reading a thread before ordering someone to search
![]() ![]() Last edited by joe231; 11-03-2013 at 02:14 PM. |
#14 |
Re: K10 Blazer HELP
I'm having trouble finding the build thread here, but how about a link with lots to see?
![]() http://lmgtfy.com/?q=Trazer Pic I stole from pirate4x4 of a custom rear crossmember
![]() ![]() Last edited by joe231; 11-03-2013 at 02:13 PM. |
#15 | |
Re: K10 Blazer HELP
#16 |
![]() Join Date: Feb 2013
Re: K10 Blazer HELP
Here is a pic of an 80 K5 that i parted out a while back, the PO cut the back of the blazer tub off and welded on the rear of a pickup truck cab onto it. After seeing how much time he spent splicing the two together I firmly believe it would be far easier to fab up a rear cab mount on the blazer frame instead.
I have considered doing the same project every time I part out a K5, I think it would be a great off road toy/plow truck, being the short wheel base gives you the option to fit in smaller places. -Sam
1987 Chevy R30 CC 454/4spd Work Truck 1979 Chevy K10 SWB 350/4spd/NP205, 1979 Chevy C10 LWB 350/TH350 Project 1981 Chevy K30 350/Th400/NP205 1986 Chevy K30 CUCV 6.2L/TH400/NP208 |
#17 | |
![]() Quote:
#18 |
78K & 79C Jimmys
Re: K10 Blazer HELP
some of early ones were removable
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
