Old 11-01-2013, 03:35 PM   #1
willett
Another Day, Another Dollar
willett's Avatar
HEI guys I need an opinion
I was doing something under the hood completly unrelated and nowhere near my carb when I noticed my main HEI power lead (red 8ga from fuse block) had a really sh*tty bare and green spade connector on the coil end. I cut and replaced the end and when I fired the truck up the next day it seems my idle is 500 or so Rpm higher than it was before.
Is there any conceivable notion that having a stronger spark could bump my idle up?
I checked my throttle linkage and it is not hanging up or sticking. I haven't been anywhere near the carb lately. It's a 600cfm edelbrock with mechanical secondary if it matters
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 11-01-2013, 10:47 PM   #2
manimal
manimal's Avatar
Re: HEI guys I need an opinion
was the distributor loose? You may have advanced the timing slightly...
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 11-01-2013, 11:01 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
It's possible I guess. But that's a pretty good bump for just a better connection.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-02-2013, 02:03 AM   #4
willett
willett's Avatar
Dizzy isn't lose. It seems to start easier too. Hmmph. Ill report back as I find more. I'm almost tempted to crimp the crappy end back on to see if it reverses the effect
Old 11-02-2013, 12:36 PM   #5
LONGHAIR
I could see that happening, a "bad connection" does not necessarily mean no connection at all. It could cause all kinds of problems, hard starting, missing, etc.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 11-04-2013, 03:57 PM   #6
willett
willett's Avatar
Must have been crap stuck in the carb because it levelled back out after an hour or so of driving
