11-01-2013, 05:05 PM | #1 |
Blazer Width
Can someone tell me how wide the blazers are from outside to outside stock tires. I wanted to see what the minimum width between tandem axle wheel well trailer I could use without rubbing.
11-01-2013, 11:10 PM | #2 |
Carpe manana
Re: Blazer Width
IIRC it's ~79" - don't have mine here to measure though...same as other 4wds
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
11-02-2013, 02:52 PM | #3 |
Re: Blazer Width
THanks
11-02-2013, 03:42 PM | #4 |
Re: Blazer Width
The 1970 Chevy sales brochure gives these specifications:
Wheelbase= 104 Length= 177&1/2 Width= 79 Height for 2wd= 64&1/4 Height for 4wd= 68 &1/2 That's without hardtop. Height for 2wd= 68 &1/2 Height for 4wd= 72 &3/4 With the hardtop. |
11-04-2013, 05:31 AM | #5 |
Re: Blazer Width
Blazer, Jimmys, Pickups are 79" to the widest part of the body work, the top of the fender lip to the top of the fender lip on the opposite side. If the truck has stock size tires the tires will be narrower than the body, if it's on 33x12.50s or some such (very very common) it will be likely that the tires will be wider than the body work and by how much all depends on the offset, so it's not a generic answer.
11-04-2013, 08:26 AM | #6 |
402 BIG BLOCK
Re: Blazer Width
My blazer had 33x12.5 on it and it barely fit on a trailer with 82" clear width.. The tires actually rubber both trailer fenders to fit.
If it is tight you can also load backwards since the rear is narrower than the front.
1967 C10 swb 1970 GMC Jimmy 4x4 2005 Chevy tahoe Z71 2001 Chevy impala |
11-04-2013, 06:59 PM | #7 |
Re: Blazer Width
Thanks fellas!!!
