Old 11-01-2013, 10:05 PM   #1
lowesguy
lowesguy's Avatar
Rear main seal help
Hi guys,going to redo the rear main seal on my 78 350 for the 2nd time,trying to fix the oil leak,I forgot to clean the end of crankshaft last time,so it started leaking again,any tips on how to get a good seal?
Thanks John
Thanks John!
lowesguy is offline   Reply With Quote
Old 11-02-2013, 12:46 PM   #2
LONGHAIR
Re: Rear main seal help
First, are you sure that it is the main seal, or just the pan gasket?
If it is indeed the seal, there are a few things that will help.
Start with "off setting" the seal slightly, so the the seal ends are not flush with the block, then do the same in the cap.
Then put just a dab of silicone on the ends of the seal before assembly.
Also, wipe a bit of oil on the sealing lip of the seal before putting the cap back on.
Be absolutely sure that the block and cap are clean, no burrs, gasket crumbs, silicone chunks, etc
That's really all there is to it, other than checking the pan too. Be sure that it is flat and smooth, no dimples around the bolt holes
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
