11-02-2013, 07:24 PM | #1 |
Old gas in fuel pump
My 51 chevy pickup sat for a long time before I got it.The carburetor had dust in the bowl. The gas tank contained a little red liquid that smelled kind of like gas,but was probably concentrated dye with only traces of gas left unevaporated.
I rebuilt the carb and cleaned up the tank inside. I didn't touch the fuel pump because it was full.When I cracked the line there was still some pressure built up in it. I blew out all the fuel lines and now I'm having second thoughts about the fuel pump. Would that gas under pressure remain stable or would it break down into something that would clog or damage the pump? I'm debating whether or not to rebuild the pump. Anyone have any info for me that could help in my decision?---Thanks---Jack |
11-02-2013, 07:51 PM | #2 |
Re: Old gas in fuel pump
imho
if i were you i would cmpleatly rebuild it or replace it. you have gone this far - why chance it |
11-02-2013, 08:14 PM | #3 |
Welcome Jack !
Take the advice replace it now while you can and not along the side of the road in a rain storm !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
11-03-2013, 12:12 AM | #4 |
Yes, pull it apart and clean the diaphams at a minimum.
11-03-2013, 03:23 AM | #5 |
Old pump diaphragms don't like today's fuel, especially if there's ethanol in the gas you buy. I'd look for a rebuild kit that's compatible with today's gasoline.
I'm surprised you had pressure in the lines. There shouldn't have been any. But as long as the lines are clear now and the needle isn't sticking in the seat you should be good to go. |
11-03-2013, 06:19 PM | #6 |
Thanks folks. I'm going to hook it all up and run it as is until the new pump gets here. I don't like the sound of a diaphragm failure. I wouldn't want to see my new truck paint scratched up by a towtruck.---Jack
11-04-2013, 08:08 AM | #7 | |
WARNING: If your skill level is low in this area, don't do this. If you spill gas or otherwise ignite it this is a great opportunity to burn your truck to the ground. (Ask me how I know.)
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
