11-02-2013, 07:51 PM | #1 |
Transmission Help
The truck I bought recently came with a tranny in it, the pan says 350 Turbo on it... How would I go about verifying that it really is as such?
1972 Chevy C-10 1/2 ton longbed project 1989 Chevy 1/2 ton shortbed "If a man does his best, what else is there?" "A pint of sweat saves a gallon of blood"-George Patton |
11-02-2013, 08:02 PM | #2 |
Re: Transmission Help
compare the pan shape to one on the web, easiest way
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
11-02-2013, 08:02 PM | #3 |
The pan should be square but one corner is at an angle.
11-02-2013, 08:03 PM | #4 |
how is the fishing up in Kaw Lake???
11-02-2013, 08:18 PM | #5 |
Thanks guys I appreciate it.
Mike- Im not a big fisher but my friends dad is and he did very well everytime he went out. Are you originally from the area?
11-02-2013, 08:32 PM | #6 |
We have success, It is square with an angled corner on it.
Next question I have... If i get a mild 402 or 454 can I use this transmission?
11-02-2013, 08:35 PM | #7 |
It should handle a 402 with some care not to beat on it every time the light goes green, but I definitely wouldn't trust it behind even a stock 454. At that point, the TH350 should be upgraded, or possibly a swap to a TH400.
71 K20 64 GMC mud truck |
11-02-2013, 08:36 PM | #8 |
From one Okie to another. I always thought a turbo 400 worked best with a 454. My 2 cents.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
11-02-2013, 08:39 PM | #9 |
Thanks for the input guys... I was thinking a Turbo400 would more than likely be needed but as I am not experienced with transmissions I figured it best to ask
11-02-2013, 08:40 PM | #10 |
I'm old school but a 700r4 is hard to beat.
11-02-2013, 08:51 PM | #11 | |
A properly built TH350 would handle the power, but is it worth it? By the time you build the 350, you could buy a new 400. Only thing with the 400 is the extra rotating mass eats a little extra HP.
11-02-2013, 09:00 PM | #12 |
Thanks for the help. 700r4 looks like it will be a little too expensive
11-03-2013, 10:16 AM | #13 | |
I agree the 400 turbo is the way to go with a big block, but you have to change drive shaft and yoke, and detent setup
11-03-2013, 11:32 AM | #14 |
Bigmac73- Small world ehh? Thanks for the info 400 turbo is the way I'm going to go. Is the driveshaft,yoke and detent setup hard to change?
1972 Chevy C-10 1/2 ton longbed project 1989 Chevy 1/2 ton shortbed "If a man does his best, what else is there?" "A pint of sweat saves a gallon of blood"-George Patton Last edited by gunrunner95; 11-03-2013 at 11:39 AM. |
11-03-2013, 11:37 AM | #15 |
11-03-2013, 03:21 PM | #16 |
you will need a new driveshaft for the turbo400
11-03-2013, 03:50 PM | #17 |
cdowns- Thanks, I wasn't sure if I could shorten it or if I would need a new one.
11-03-2013, 07:37 PM | #18 |
I believe the yokes are different.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
11-03-2013, 08:21 PM | #19 |
i had to shorten mine about 3 inched if i remember right, i never hooked up the detent switch back then, and i had to find a thick walled yoke,
11-03-2013, 10:58 PM | #20 |
Lattimer- Thanks
bigmac73- thank you for the info
11-03-2013, 10:59 PM | #21 |
Lattimer- Thanks
11-03-2013, 11:35 PM | #22 |
My line of thinking is this. A TH350 is a great tranny in a light low geared car/truck. You may also consider a BUILT 700R4. I had one behind a 431 cu. in. Olds for quite a while. It didn't get hammered all the time but it did have some torque pushed to it. I used to boil 12x33x15 MS tires with it in the truck. The 700 is still in one piece. I attribute that to the big @$$ cooler that was installed with it.
I hope I didn't jynx it.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
11-03-2013, 11:45 PM | #23 |
Longhorn70- I appreciate the info. I was planning on getting a 454 from a motor home as I have read on here where many had done so with good results. I do tend to be throttle heavy in my 89 with a 350, but I would have to me more careful with a big block local cops seem to love pulling over teenagers driving trucks
