Choke dash label question
Hi everyone,
I'm relatively new around here, and have searched past posts for the answer to this question but couldn't find where it had been asked before... I see that on those dashes with manual chokes there seems to be two different ways they're labelled on the dash - one with it apparently part of the dash panel as seen in the top most pic in this post: http://67-72chevytrucks.com/vboard/s...d.php?t=200203 and one where the label for the choke is on a plastic add-on tab, seen in the second picture in that post. Why the difference between the two? Is it year-model difference? Does anyone make reproductions - or know where to find - the plastic add-on tab? Thanks |
![]() Join Date: Sep 2010
Re: Choke dash label question
I put a " wanted choke plate " ad in the WTB ( wanted to buy ) area of this website and bought the one pictured below for $10 a few months ago. I'm not sure why some are " added on " - it might be since the 67 - 68's have the wiper and light switches both on the left of the dash, they put the choke in the upper right. I think only the base engines had a manual choke. The 67 - 68 trucks with an automatic choke had a choke delete plate on the upper right corner of the dash, like in the second picture, below. I've never heard of anyone making a reproduction of the choke plate. Someone else might know more about it. . . . . |
Welcome to you from East AR. My 68 GMC doesn't look like either of your pics, it had an add on button looking thing. I will try to look at my 68 parts truck tomorrow to see what it is like. Jim
I wish I could find a plate only that says "wiper". I bought wiper delays from Roger (twouvakind) and prefer to have the reostat dash mounted so I could have both, 1) the hi/lo/off and 2) the delay. I have a Burban with rear air and it came with a Rear Ac plate on the left side of the cluster.
Thanks for the info you guys. Steve, I found your ad in the WTB section and messaged too_much_stuff, he still had one available. I appreciate the info and the pointer
hugger, hello from central Ar. Nice to see someone from close by on the site. GuyO, I didn't know they made a plate like that. The choke one seems fairly common - just not reproduced - the throttle plate I'd imagine would be less so, and now I find out there's a rear AC plate, which I'm sure is really uncommon. I wonder if there are any other dash plates? |
#6 | |
Roadtrip!
![]() Join Date: Feb 2003
Choke throttle Diff lock Fuel stop
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
I didn't realize there were so many different types of them! I had only seen manual choke and rear AC. That said, you gave me an idea. I think I will make one for the wiper delay from an old broken cluster I have and place it under the main wiper switch on the right side! I can make more from other clusters I know of. So the Burban will have 4 knobs, the Blazer and GMC SWB will have three knobs (except on the right side both say "wiper" above the knobs)
