Anybody else make a rear slip driveshaft other than CPP?
I have a 71 LWB truck and need a slip driveshaft for my truck. It's the driveshaft that runs from the carrier bearing back to the rear axle. I see that CPP makes one but was wondering if anyone else sell one as well.
Thanks |
![]() Join Date: Mar 2012
Re: Anybody else make a rear slip driveshaft other than CPP?
my local drive shaft shop quoted me 700 to upgrade to a 3inch tube, with all new 1350 series joints from tranny yoke to pinion yoke with carrier bearing installed, to include making a slip joint style
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Registered Cruiser
I had one made for
$125 at a driveline shop here in Vegas.
I intend to live forever. So far, so good. |
Go to these guys for a quality unit: http://www.iedls.com/Driveshafts/Critical-Link.asp
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
#5 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
My truck is bagged. The style carrier bearing I'm using require a slip drive shaft between the carrier bearing and rear axle to compensate for the up and down travel of the suspension.
#7 | |
Old member
![]() Quote:
