Old 11-03-2013, 05:14 PM   #1
Branman1971
Branman1971's Avatar
Can't decode my 350
I'm having trouble decoding my 350. I can't find the VIN stamp on the block and what I can find doesn't jive with the NastyZ28 website I am using. I will post some pics of what I can find and maybe y'all know what's going on? These numbers are on the block above the oil filter on passenger side.
Active duty Navy CPO
1961 C10 SWB
1963 C10 LWB (donor)
1965 C10 LWB BBW
Branman1971 is offline   Reply With Quote
Old 11-03-2013, 05:22 PM   #2
Branman1971
Re: Can't decode my 350
This is stamped forward of the block passenger side on the fuel pump housing.
1961 C10 SWB
1965 C10 LWB BBW
Old 11-03-2013, 05:30 PM   #3
Branman1971
Normal big stamp on drivers side rear of the head.
1961 C10 SWB
1965 C10 LWB BBW
Old 11-03-2013, 05:32 PM   #4
bama63
bama63's Avatar
drivers side rear of block just below deck where trans bolts up such as, 1969-79 casting no. 3970010 =350 with 185hp, 370tq 2 or 4 bolt mains available in car, truck, Vette
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 11-03-2013, 05:41 PM   #5
Branman1971
This is on rear of block just under distributor.
1961 C10 SWB
1965 C10 LWB BBW
Old 11-03-2013, 05:46 PM   #6
Branman1971
It does have 4-bolt main. YAY! Just wondering if I can find what it came out of.
1961 C10 SWB
1965 C10 LWB BBW
Old 11-03-2013, 06:44 PM   #7
MARTYZ
MARTYZ's Avatar
Are there no #s on the right side deck just infront of cylinder head, if not some one may have machined the block deck at some point, they will be stamped in not cast in.
MARTYZ is offline   Reply With Quote
Old 11-03-2013, 09:27 PM   #8
Branman1971
Ok...I'm gonna go see the eye doctor. I just found the number you speak of. I have been all over this thing and didn't see it till just now.
Says: 72 350
application:conv.cab,a/t
Hp: 175
Bbls: 4
Body: C10&20
80 350
Application: van&bus, a/t
VIN: L LS9
Hp: 155
Bbls: 4
Body:C10-2500
Narrows it down a bit.
1961 C10 SWB
1965 C10 LWB BBW
Old 11-03-2013, 09:29 PM   #9
Branman1971
Thank you MartyZ!
1961 C10 SWB
1965 C10 LWB BBW
