Old 11-03-2013, 06:42 PM   #1
ItWillBeSlow
ItWillBeSlow's Avatar
72 Gas Pedal Replacemen
I just purchased a Brothers gas pedal for my 72 that currently does not have one. I am not with the truck for the time being to confirm, but I dont beleive I have a pin or any way to attach the pedal to the truck. Pedal just has 2 raised 'lips' for attachment the accelerator 'rod'. I will try an attach a picture. what am I missing?
I apologize for the pic, the floor mat is covering the tip of the accelerator, but I think shows most of it,.
Side note... does anyone else else have a brothers pedal and think its pretty cheap/flimsy?
ItWillBeSlow is offline   Reply With Quote
Old 11-03-2013, 07:28 PM   #2
franken
Re: 72 Gas Pedal Replacemen
There's a pin and spring needed to attach the pedal. I'm sure they're available aftermarket, and maybe in the help section of the parts store.
franken is offline   Reply With Quote
Old 11-03-2013, 08:12 PM   #3
engineer_gregh
engineer_gregh's Avatar
Where are you at in TN? I have a spare pedal and spring if you need and not to far away.
engineer_gregh is offline   Reply With Quote
Old 11-03-2013, 08:49 PM   #4
ItWillBeSlow
Ok guys, I think I see what you mean. LMC catalog has an exploded view, page 134,
http://media.lmctruck.com/pdf/CB/cbComplete.pdf
(3) PEDAL RETURN SPRING CHEVY GMC 71-72 (1) 3.69 2.95
(4) PEDAL RETURN SPRING PIN CHEVY GMC 71-72 (1) 2.44 1.95
engineer_gregh, I am about 30 miles west. I appreciate the offer, but since they're so cheap and Im about an hour from you Ill just throw them in with my LMC order. Thanks lot!
Old 11-03-2013, 09:42 PM   #5
engineer_gregh
Anytime. Good luck with the truck.
Old 03-23-2018, 10:35 PM   #6
lux
I have to revive this old thread. I am also replaceing my peddle with a SandManDesigns one.
I have the accelerator return spring pin, but I don't know what holds it in there. Is there supposed to be a nut on one side? Or does it just stay in place with the spring? Mine is old and rusty and I can't tell if it's whole.
lux is offline   Reply With Quote
Old 03-24-2018, 03:09 AM   #7
'68OrangeSunshine
'68OrangeSunshine's Avatar
Spring tension holds the guide pin in place. The pin has a groove in the middle. This rides in a hole on the center of the Pedal.
If you get a fresh spring and clean up the other stuff, you'll figure it out. It's not rocket/surgery.
Old 03-24-2018, 08:24 AM   #8
lux
Thanks OrangeSun, I'll give it a try.
