what would you do? rear suspension??
for rear suspension. I have a 69 panel truck. I have a big, big block. plan on a bottle. 750HP on engine. I like the idea of using the factory long arms and good coil overs. But, would it hook up better if I did use a ladder bar set up? I have a narrowed rear, ladder bars and coil overs from a Malibu I was gonna tub. I wasn't going to "tub" this, but just open the wheel wells and run some 31x12's Not really sure how it's gonna hook up. I figured with all the extra weight, it would do fine...
Re: what would you do? rear suspension??
The truck arm acts like a ladder bar. Only longer which could be a major help for a long loe icg. Lower the front mounting point for less initial hit to the tire.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
As Super said, drop the front mount point 6" and stuff some tire under it. Mine really hooks well with the $14 rear shocks from O'reilly's on the rear..
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive Interior 1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories My momma took me off the bottle years ago..... |
Does somebody make a mount kit? or is this something i have to fab up.
Search for a thread I started in this section regarding adjustable lca mounts. Cheap and easy to make. Or buy the grossly over priced ones from hodgkis.
| Bookmarks |
