Old 11-03-2013, 09:50 PM   #1
68'CTown
68'CTown's Avatar
Engine Frame Brackets Help
I have a 68 Chevy Truck and just got done putting in the whole 74 cross member and front suspension and did that for the easy disc brake conversion. What engine frame brackets do I use for a small block?
Thanks!
Craig
- Every day is a new opportunity. You can build on yesterday's success or put its failures behind and start over again. That's the way life is!
68'CTown is offline   Reply With Quote
Old 11-03-2013, 10:01 PM   #2
bbcmudtruck
Re: Engine Frame Brackets Help
The stock 73-86 sbc engine brackets will work just fine. If your putting in a bbc, I've been told you need to use the 68-72 bbc mounts, however I don't see why? The newer mounts should work with the bbc as well. I have the same cross member etc in my 69.
bbcmudtruck is offline   Reply With Quote
1968 c10, engine mount, frame bracket
