11-03-2013, 09:56 PM | #1 |
wheel fitment
I tried searching couldn't find what i was looking for. I came across a set of 16" six lug factory wheels off a 2004 gmc. I was curious if these would fit my 1968 c10? Any help with be great.
11-03-2013, 11:03 PM | #2 |
Re: wheel fitment
The bolt pattern is the same, so they will bolt up. Depending on the offset they may "tuck" or "poke".
70 CST, 6.0/ 4L80E in the works. *Custom harness by 68 Short Step* |
11-04-2013, 01:35 PM | #3 |
Re: wheel fitment
Backspacing is one issue. You're biggest hurdle will be with your hubs bore size. The bore opening on those wheel will be 78.3mm. I believe the 68 is a 108mm. You would either have to have the center of the wheel bored out to 108 or buy wheel adapters.
11-05-2013, 10:33 AM | #4 |
Re: wheel fitment
thanks for the info.
11-05-2013, 11:59 AM | #5 |
Old member
Re: wheel fitment
Here are a couple.
One of the prettiest wheels GM has produced in a long time to me.
