Old 11-04-2013, 01:51 AM   #1
JAM1777
torque converter
Hi everyone, im restoring a 1969 c10 long bed. It has a fresh rebuilt 350 small block and a turbo 350 transmission. I want to know what brand and type of torque converter would be best for this tranny and motor?? My uncle has a 65 chevy c10 and it has a new torque converter and it has a quick takeoff. So i would like torque coverter recommendations. Thanks for any info.
JAM1777 is offline   Reply With Quote
Old 11-04-2013, 10:11 AM   #2
Longhorn 70
Longhorn 70's Avatar
Re: torque converter
Welcome to the board....
Tell is more about the engine/cam combo and rear end gears.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 11-04-2013, 05:23 PM   #3
JAM1777
Im not sure what kind of cam i have or rearend. When i bought the truck the engine was just rebuilt. How do i find out what kind of cam and rearend it has?
Old 11-04-2013, 05:32 PM   #4
JAM1777
Ok i just called the previous owner and he said the rearend is a stock 70 10bolt and it has an old cam called a crower torque master. Any info on a compatable cam would be appreciated thanks
Old 11-05-2013, 01:28 AM   #5
JAM1777
Thanks for Any info on what type of torque converter i should use with my cam and rearend setup.
Old 11-05-2013, 06:37 AM   #6
bigmac73
bigmac73's Avatar
you need to figure out what size gears are in the rear end, but in general i would recommend a B/M Holeshot with a 2100 RPM stall,
Also you need to look more into how your engine is set up and carb, timing, ect ect, sometimes a quick take off is not all about a stall converter
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 11-05-2013, 11:18 AM   #7
Longhorn 70
Agreed on the Holeshot. As I recall, the crower torque master liked 1800-5000 RPM range. This would be great if you have 3.73s or 3.42s
Now what kind of driving do you want to do with it? Do you want it to be a weekend cruiser, daily driver, raceday and show only?
I use a stock lockup converter in my 700R4 because I want fuel economy when I go on long trips/cruises. PLUS the low stall helps keep the engine from revving too much.
Old 11-05-2013, 03:55 PM   #8
JAM1777
It is a daily driver now and i want to turn it more into a weekend cruiser as soon as i purchase another vehicle. I really dont want it show to where you cant even touch it. But i want it to look nice and have some nice power and kick when you hit the gas
Old 11-05-2013, 06:50 PM   #9
Longhorn 70
is your cam lumpy at all or nice and smooth? If there is any lump you may want a 2500 RPM stall.... If you have a higher stall, it's like revving the engine a little higher and dumping the clutch. If you have 900-1000 RPM stall it is like taking off from normal rev and with a lumpy cam you may feel it. A higher stall is like revving the engine to a higher (flash) RPM and letting the clutch go.
Call or bring the truck to a tranny shop and see what they say.
Old 11-05-2013, 08:27 PM   #10
JAM1777
Ok you said the Holeshot would be great if i had a 3.73 or a 3.42. Im new to this stuff so im not sure what that is. Is it rearend gear ratio? And if it is i have a stock 70 ten bolt rearend if that helps. Does a stock 70 ten bolt come with a standard set of gears in it?
Old 11-05-2013, 08:29 PM   #11
JAM1777
And you asked if my cam has any lump to it. Im not sure what that means either.
Old 11-05-2013, 08:38 PM   #12
bigmac73
bigmac73's Avatar
when it idles does it sound smooth?? or is it Lopey? if you are not familar look up some videos on youtube of different engines idles ,
do a search for a different idles with different cams
Mike
Old 11-05-2013, 08:40 PM   #13
bigmac73
bigmac73's Avatar
go outside and clean your rear end real good go over it with a wire brush and some solvent and try to look for different numbers, there are guys on here that can help you convert them over and maybe you will see a gear ratio on the tubes or cover somewhere
Mike
Old 11-05-2013, 08:41 PM   #14
JAM1777
It sounds lopey with a lot of compression
Old 11-05-2013, 08:47 PM   #15
bigmac73
bigmac73's Avatar
http://www.hemmings.com/hmn/stories/...feature29.html
read this and do some research
Mike
Old 11-13-2013, 01:52 AM   #16
JAM1777
Ive done some research and found two torque converters that seem good to buy but wanted some opinions cause im learning as im fixing my truck. I have a rebuilt 350 small block with a turbo 350 transmission and im hearing the BM holeshot 2000 is good and im also hearing that the Edge street racing mild street edge converter is good also, but dont have enough Knowledge in this area to know which is better. Any help or opinions would be great.....thanks
Old 11-13-2013, 10:12 AM   #17
bbcmudtruck
I'd try the holeshot. Its really not that much stall. You don't want to over stall the trans if you don't have the motor and or gears to back it up.
bbcmudtruck is offline   Reply With Quote
Old 11-14-2013, 02:09 AM   #18
JAM1777
Ok B&M holeshot2000 is what im going to order. A couple more questions though. Earlier in this thread someone asked if my cam was lopey or smooth and i said lopey. But a mechanic i talked to said it was smooth. So is the holeshot still a good choice?
Old 11-14-2013, 08:36 AM   #19
bigmac73
bigmac73's Avatar
yes, i had a 72 C-10 years ago with a 300HP crate engine nice smooth idle , a little better than stock with a turbo400 tranny and 3.08 rear end gears, the holeshot worked great for me , you will be fine
Mike
Old 11-14-2013, 10:22 AM   #20
Longhorn 70
Holeshot is a tough converter too. They work hard. Good Choice.
