11-04-2013, 02:46 AM | #1 |
what to use to fix the overflow on radiator
Has anyone had experience using Q-bond? I need to fix until I can get it properly fixed.
1968 C10, 250, L6 4spd OTF, Fleetside Upgrades: Power Steering .......................____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
11-04-2013, 07:37 AM | #2 |
Re: what to use to fix the overflow on radiator
No experience with that, i have used the 5 minute epoxy stick...play dough type stuff though....good luck!
11-04-2013, 08:28 AM | #3 |
JB Weld
Or just get a propane torch and fix it yourself.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
11-04-2013, 09:15 AM | #4 |
Solder,it's not that difficult. Why halfass it?
11-04-2013, 10:13 AM | #5 |
Active Member
Unless you're dead broke, I'd take the whole thing off (about 30 minutes to an hour). Shouldn't cost that much to have it re-soldered.
If the radiator is otherwise in good shape, you might want to have it rodded and clean while it's out.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
11-04-2013, 10:57 AM | #6 |
what he said and it is easy to do clean it flux it solder it
Fuzzy |
11-04-2013, 11:30 AM | #7 |
I've seen a bolt on valve stem used as a temporary fix. Clean off the area, bolt in the stem, remove the valve in the stem and hook your overflow hose to it.
Here's some examples. Should find some at a tire store. http://abc.eznettools.net/accessorie...alveStems.html |
11-05-2013, 12:34 AM | #8 |
Agreed I will pull it off and have it re-soldered. Thanks
11-05-2013, 12:43 AM | #9 |
I think if I had that issue, I'd call the local radiator shop. That said, a new radiator really isn't that much. I got a 3 row from Advance Auto for less than $200.00. Now I don't know what your budget is but it is a radiator....pretty important to the truck's functions.
I did have to get the actual part number for the radiator, Advance Auto didn't know what I was talking about. |
