Old 11-04-2013, 09:55 AM   #1
pound41
H4 Headlight Conversion
Anyone running H4 new style headlights on your blazer
If so what and where did you get them. Do they make a difference
pound41 is offline   Reply With Quote
Old 11-04-2013, 03:45 PM   #2
Sacramento70
Blazer Fanatic
Sacramento70's Avatar
Re: H4 Headlight Conversion
I did a headlight relay upgrade and got some hids the fit in a 7" round housing that except h4 headlights..i think it made a huge fifference...more clean power and better light output
1970 Chevy blazer
Sacramento70 is offline   Reply With Quote
Old 11-05-2013, 03:26 PM   #3
jaros44sr
jaros44sr's Avatar
Me too, i would like to know....did the relay upgrade, but would like to know more about the lights, and where you got them
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-05-2013, 04:00 PM   #4
Sacramento70
Blazer Fanatic
just some cheap autopal 7" round housings ...check ebay there the euro style ones for $24
the hids are cheap as well there a kensun set that cost about $40-60 after shipping ....i went cheap on the housings and bulbs because it was my first time doing this and i wanted to make sure i got it right before i put out some real cash
overall im happy with this little setup, i think ill wait till it quits to do a better upgrade
heres the links to what i bought
housings - http://www.ebay.com/itm/7-H6024-6014...item35984afe42
Hids - Kensun HID Xenon Conversion Kit H4/9003/HB2... Kensun HID Xenon Conversion Kit H4/9003/HB2...
(these are similar but mine are 6000k)
hope thats helps
1970 Chevy blazer
Old 11-05-2013, 09:09 PM   #5
Mike C
Mike C's Avatar
I put AutoPals on my Datsun and regretted not buying the Hellas. Autopla light was good just plastic lenses. 4 Wheel Parts has the Hellas for $35 each.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-06-2013, 09:33 AM   #6
RANDAL
RANDAL's Avatar
Yep I will be getting the harness that VH Coachworks sells for the GMC, DDM tunning HID's, and 7 '' Hella housings for my Jimmy for xmas total for eveything is going to be around $350 I have looked in on this for a long time now and the Fiance said she will buy them for me for Xmas so I will be ordering them next week.
GMC Jimmy and Chevy Blazer the real mans convertible.
RANDAL is offline   Reply With Quote
Old 11-07-2013, 04:16 AM   #7
Sacramento70
Blazer Fanatic
hmmm...my lenses are solid glass and for the $24 they sent 60 watt halogens as backups....what lenses did you get , just curious
1970 Chevy blazer
Old 11-07-2013, 04:19 AM   #8
Sacramento70
Blazer Fanatic
sounds like a good setup but if i was you i would do a little research and build your own harness, its good practice and you can build it cheaper then what he sells if for, plus you gain experience and get to take pride in doing it yourself
1970 Chevy blazer
Old 11-07-2013, 07:59 AM   #9
RANDAL
RANDAL's Avatar
Thats a good idea, might half to try that.
Old 11-07-2013, 01:54 PM   #10
jaros44sr
jaros44sr's Avatar
I think, all you have to worry about is the gauge of the feed wire, has to be bigger to handle more amps, IIRC. M&H built my relay harness, and i forgot to mention this to them, so, when i put those lights in ill go back and change that wire
I agree with sacramento, the more i get into the electrical side the easier it gets. With quality tools and connectors, it can be done in your garage. You always have the electrical forum down below to help you out. Great group of guys with lots of knowledge
SAFETY FIRST
AS usual, off topic
Jim
Old 11-07-2013, 08:48 PM   #11
Mike C
Mike C's Avatar
They were a kit that came from Motorsport Auto over 10 years ago. Hadn't event considered looking to see what might be new. I LOVE the flat lens and general look of the Hella's and $10 more each can't sway me.
Funny thing is I don't have them on any Chevrolets! My '44 Willys MB has a 5" set, my '79 CJ-5 and my '52 M38A1 all have the Hella's. And I have another set for my '69 short step when I start driving it more (need to disc/5 lug swap). Guess I should get a set for my Camaros come to think of it.
Haven't looked into whether you can get a 2 separate light setup for the GMC, anybody?
44 Willys MB
52 M38A1
64 Corvette Coupe
