11-04-2013, 08:05 PM | #1 |
fun messing with dealer ships oil change department
i to 67 today to local car dealer for free oil change well to start dude jumped in truck tried cranking in gear told him 3speed on colum well he yelled out any one know how to drive 3 speed ,well they put it on rack and had oil filter wrench in hand but its the canister oil filter i new all this but wanted to see looks on there face they had to call old man from another department to tell them how to change it but they got it done.
11-04-2013, 08:09 PM | #2 |
Re: fun messing with dealer ships oil change department
you are brave. I don't let the dealership touch my new cars any more, never mind my 70.
11-04-2013, 08:21 PM | #3 |
ooo i know i watched them do every thing real close to make shore they done everything right cause last time anyone done it i notest a little oil leak they nevered put o ring on top of canister i was little upset .
11-04-2013, 09:32 PM | #4 |
Ha! had to call an old guy in.... That kinda cracks me up. Did you get it on video?
Some newer cars have cartridge type filters too. My wife's RAV4 V6 has a cartridge type filter. I let Toyota do the changes while it was under warranty. Now I do them. It amazed me that they could do an oil change faster than I could drain the old oil. We'd wait in line for 60 minutes, they'd bring the car in and bang 15 minutes later it was out. They washed it and did paperwork in that 15 minutes too....
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
11-04-2013, 10:37 PM | #5 |
The last few years that I worked in dealerships, I was the "Old guy" that they would call in. If anything with a carburetor or distributor came into the shop, they were lost. Most of these kids had never even seen a carburetor.
"Negative people always seem to have a problem for every solution" |
11-06-2013, 09:27 PM | #6 |
mine still has points too
11-06-2013, 09:37 PM | #7 |
Vintage 4x4s
Nice looking 67 you have there! Is that original paint?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
11-06-2013, 09:40 PM | #8 |
its has been painted once years ago. just painted over original original coming back throw in spots where paints chippin
11-06-2013, 09:43 PM | #9 |
its had only a 1000 miles put on it sense 2002 but know its my daily driver
11-06-2013, 10:08 PM | #10 |
That stuff is funny..... I took mine about a month ago too and had a similar experience. They got it in the stall and they called me out to ask where to check the oil.. then asked me where to fill it as well??? LMAO!
If I see a Zombie.. Im runnin it over with my Truck. |
11-06-2013, 11:49 PM | #11 |
If you guys have your oil changed, what do you do about lubrication. Greasing all the fittings on these are critical. I do my own but I wonder about the Jiffy-lube guys. You know they don't know were all the fittings are.
11-07-2013, 10:58 PM | #12 |
i do my own oil changes just had a free change and didn't fill like it should go to waste all fitting full of grease
11-07-2013, 11:26 PM | #13 |
Its possible to change oil in 15 minutes. The key is a lift, not lubing the chassis and not actually letting Ll of the old oil drain out!
11-08-2013, 12:03 AM | #14 |
I promised "the old guy" at the Honda shop I'd bring the truck over when it's running so he could see it.
Actually, the shop won't take such an old vehicle! Great shop though, I don't trust Sears with my oil changes anymore. Along that same line as the OP, the radiator shop that renewed my tank, the owner and I got to talking, he said "my newer guys can't even drive a manual! I have to get the older guys to drive those trucks when we do get them in here." He also said (Honda "old guy" confirmed) that GM no longer makes a "work truck" everything now has AC, auto tranny, and carpet. |
11-08-2013, 01:56 AM | #15 |
I used to be 'the old guy that knows'- only because I've been around long enough to have the tools and the knowledge. I got metric and British tools early on, and saw all the 'furrin' stuff', for quite awhile. I'm pretty well-versed in the new stuff, and I marvel at the changes and improvements. That being said, I would never take any of my iron into a dealership or quick-lube place. It's pretty hard to find a guy like me in a shop anymore, and I'm retired (at least semi-retired, still doing English bike and old German stuff, for a select clientele).
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
11-08-2013, 10:48 AM | #16 |
x2
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother |
