Southern Nevada Coal Roller
What's the wheel base of a 67 crew cab long bed made out of suburbans?
For the people that made a crew cab out of a Suburban. What is the wheel base for a crew cab long bed truck. Did you use your suburban frame and lengthen it or did you buy a late 70's crew cab long bed truck frame?
I am just doing some research right now. I need a truck more than my suburban. So am just wondering about wheelbase and frames used. thanks Chris
Chris 72 Suburban, 1 ton dodge chassis 4wd cummins, DTT 47rh 89%, PDR VE 3200 spring, PODS, Piers Turbo. 36 Chevy P/U rat rod project. 4bta cummins ![]() |
Re: What's the wheel base of a 67 crew cab long bed made out of suburbans?
Not sure but I have a suburban frame you can have
![]() Join Date: Apr 2013
Suburban frames are different in the rear section from pickups, so you'll have to take the back half of a '67-72 pickup frame and mate it to front half of the '67-72 burban frame.
Now taking a '73 up frame will create it's own problems, radiator mounts, body mounts, bed mounts all different. Fuel tanks will not work with '67-72 cabs (especially because of the fuel tanks and the cab mounts and floor pans are way different). I suggest you keep the frame all '67-72 and minimize the problems, you'll have enough things to think about in the creation of a crew cab in itself. I've done a lot of research on doing the crew cab creation and have started it but had to put it on hold till I complete a few other projects.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
Thanks for the info. I know its a lot of stuff to do. My suburban is sitting on a 90 dodge one ton frame so I really don't have an option of using the suburban frame. I do have a 2004 dodge 2500 with a new cummins that I thought about using, but Starting with a fresh frame would be nice.
lots to think about. I also 68burbanontherocks said he would build me a custom tube chassis. lol Chris
