Old 11-04-2013, 09:09 PM   #1
Hook0215
Lowering springs vs. Cut coils????
Which is better and how much of a drop is cutting one coil from a stock spring?
Hook0215 is offline   Reply With Quote
Old 11-04-2013, 10:05 PM   #2
ymerej71
ymerej71's Avatar
Re: Lowering springs vs. Cut coils????
I would say cut your coils first... See how you like the drop & ride before you drop cash on lowered springs. Cutting (1) full coil equals approx. a 2" drop in ride height after the springs settle. Many of your static drop trucks in the 4-5" drop range are running dropped spindles and cut coils. It really all depends on how much drop you're wanting to achieve. Chances are you'll want it lower than you originally thought. Good Luck!
ymerej71 is offline   Reply With Quote
Old 11-04-2013, 10:36 PM   #3
Sodell
Sodell's Avatar
Don't forget to save some money for an alignment.
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 11-04-2013, 11:21 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
Either way the spring rate changes. worn shocks will give you a bad day
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
