11-04-2013, 09:34 PM | #1 |
59 Apache with 94 Blazer cloumn and pulse wiper motor
Hey guys,
Been awhile since I've worked on the truck and been on here. NEED MORE HELP!!! History: I installed a 94 Blazer steering column with the pulse windshield wiper motor for the same donner. I also scavenged the wiring plugs... You guys got me straight on the linkages awhile back and they are in and good to go. I am now working on the wiring: the motor has wires white, grey orange and purple and the column has about 10 going in and the 4 going out to the plug that attaches to the motor... I have a diagram that says white is hot to the motor... what color is the wire on the column to get power to the switch on the turn lever. I assume I need power in both place???? but not sure... What do I do the get the system working? Thanks, Scott |
11-05-2013, 03:57 PM | #2 |
Re: 59 Apache with 94 Blazer cloumn and pulse wiper motor
there is a Wiper Motor Pulse Board Module that you should have grabbed also.
i did a search for ''94 Blazer steering column with the pulse windshield wiper motor'' right off your post and found that in 5 seconds
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
11-05-2013, 04:53 PM | #3 |
When I got the system it was together ,although in a totaled vehicle so not sure if it worker. I got the complete column with original sock connectors, all wiring between the column and the wiper motor and the wiper motor it self. from the connector a that connect the two there is one red wire that looked like it went to the fuze panel not sure, but it is the only wire I cut. On the column at the connecter bear the base I have 9 wires coming in from my Painless wiring system, but there are 10 wires on the column connector, plus what I think is the cruise connector 4 wires. Looked at many diagrams on line and still can't figure out how to get it working.
11-05-2013, 09:39 PM | #4 |
59 Apache with 93 Blazer cloumn and pulse wiper motor
OK gang,
Still need HELP I have looked on-line, no luck. Went to Auto Zone, Napa and Advanced, no luck. The controller module is part of the wiper motor and in place. I uploaded two slides with my current situation, on the 93 Blazer Wiper problem. I Need wiring diagrams or someone with wiring knowledge to provide me guidance on how to make this work. It is the last thing unfinished on the 59's wiring.... Everything else works!!!! Lights, heater, motor, elec fan, everything..... Bottom Line Up Front (BLUF) military term. I need to know what the terminal locations on the column connector do: G which has a Black wire F which has a Green wire and E which has a Brown wire Thanks, Scott |
11-06-2013, 02:53 PM | #5 |
Check this out,
http://www.s10forum.com/forum/f62/if...agrams-408087/ Couple of members there have wiring diagrams that may help. Frank |
11-06-2013, 04:10 PM | #6 |
took me 5 min to find this
the green and brown wires are probably feedback to the bcm for the key buzzer for the wipers: white-12v+
