11-05-2013, 12:07 PM | #1 |
Painting an L6 mainfold
I am painting my intake manifold and was going to use chevy orange. Is it necessary to use a high heat paint like header paint 1200 degree or engine paint rated at 550 degrees would work?
11-05-2013, 01:32 PM | #2 |
Re: Painting an L6 mainfold
Standard engine paint will work on the intake just not on the exhaust manifold. I would definitely use the clear coat in addition to the color coat.
1971 Chevy C10 Cheyenne (sold for Mazda) 1963 Chevy Corvair Pro-Touring Project 2012 Mazda 3 i Sport sedan http://www.dracoautodesigns.com/ |
11-05-2013, 03:10 PM | #3 |
I am a Referee of life.
Biggest thing is prep.Get it clean.Sandblast if you can or use a wire brush on a drill and really get it as clean as you can.Then wa**** well and use laquer thinner to clean it even more.After that paint it well.I haven't tried clearcoat but it should help keep the paint better.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
11-07-2013, 10:57 AM | #4 |
I painted using VHT Very High heat manifold paint. Their engine paint goes up to 550 degrees this is like 1300-2000. Looking at the old pictures the original manifold paint was completely gone around and under the carb probably from gas leak more than anything but decided to go with higher temp paint.
Think I like the black better anyway. Thanks for the help!!!! |
11-07-2013, 07:11 PM | #5 |
Six in a row makes it go...
It's not orange, but I used Eastwood's high-temp.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
11-07-2013, 09:35 PM | #6 | |
Looks good guys! |
