Old 11-05-2013, 03:53 PM   #1
teamssc
Looking for a points distributor
I know the 1001 reasons to stay with an HEI unit and not go to a points distrib but I'm feeling nostalgic. I used to have a 72 Nova with points. I want to have the experience of swapping a points unit in and our of my 78 sb 350. I can only guess if the engine is a 78 though the carburetor does decode as such. Anyway how do I determine if it's HEI? Its got a coil in the cap so that might be all I need to know, short of taking the cap off.
Anyway if I'm looking for a used distributor what can I buy? Anything with points that is for a Chevy or do I have to determine if it fits a 350 truck? I see a lot on ebay $40 to $70 delivered and I'm wondering how to choose.
Thanks for any direction you can give me.
Don
teamssc is offline   Reply With Quote
Old 11-05-2013, 04:50 PM   #2
faribran
Re: Looking for a points distributor
i would imagine there are a FEW on here to be had for the shipping charges....
faribran is offline   Reply With Quote
Old 11-05-2013, 04:57 PM   #3
77ChevySharkBite
77ChevySharkBite's Avatar
An HEI as I was told once has like a hump on it, that's the way to know it's an HEI.
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 11-05-2013, 04:57 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
First off Don, I say stick with the HEI and don't do the points. Have you ever laid across the top of a carburetor in a truck and worked to install points and then align the dizzzy up to get to the window to adjust the points. If you have any age on you, you will regret this move in your later years.
HEI is a very stable process and the fact that you have a dizzy with the coil in the top, tells me that you are already an owner of one.
Just my input.
Frank
piecesparts is offline   Reply With Quote
Old 11-05-2013, 07:28 PM   #5
78maliburat
Just my input.
WOW....................... in a points type dist the points are stationary
78maliburat is offline   Reply With Quote
Old 11-05-2013, 08:06 PM   #6
Pampas56
Yes the points are stationary, but the dwell angle still has to be adjusted. It has to do with the timing and time of energization of the field for the coil. If the points do not open at the right time, the timing will be off and if the dwell angle is too large, the coil will not have time to build a large enough field and you get a weak spark.
Ford had ONE better idea when they put the distributor on the front of the engine. GM had the better idea by putting an allen screw adjuster on their points.
Adjust the dwell angle first, then the timing because one degree of dwell angle changes timing by two degrees. If I remember correctly a SBC was set at .019" point gap for the proper angle (about the thickness of a matchbook cover).
To the OP: Kudos for wanting to go Old School with the point type distributor, but as a guy that pre-dates HEI and all the electronic ignition systems I don't miss laying across a running engine fiddling with the points and distributor while trying to watch the dwell angle meter.
Best of luck
1989 Silverado K2500ECLB- 307K miles with 90 K TBI 350-Not a show truck, a work tool that I can drive!
1998 Dakota EC 250K miles- I guess I'm just a truck guy now!
Pampas56 is offline   Reply With Quote
Old 11-05-2013, 08:26 PM   #7
piecesparts
Best of luck
My point exactly! OUCH and shucks that's hot and a few other explicatives.
I did my time with the old points process during my time that I worked at a County Highway Department shop. You learn to hate the old stuff and look forward to the better stuff.
Frank
Old 11-05-2013, 09:15 PM   #8
INSIDIOUS '86
INSIDIOUS '86's Avatar
You can run a points looking ignition if you want the looks. Mallory has setups with good working modules that don't need to be adjusted.
If your set on points stock up on some original ac/delco points.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-05-2013, 09:20 PM   #9
nekkidhillbilly
was it even offered in a square i know the buicks stopped in 73.
nekkidhillbilly is offline   Reply With Quote
Old 11-05-2013, 10:05 PM   #10
Axle
Axle's Avatar
GM went HEI across the board in 1975.
To the OP, put the notion of running points in your truck out of your head. Theres a reason plenty of us put an HEI in place of a points ignition in our older cars--even if it meant taking a bfh to the firewall to get it to fit.
Alex.
Axle is offline   Reply With Quote
Old 11-05-2013, 10:09 PM   #11
rusty76
rusty76's Avatar
Funny but my '76 had points. My uncle used to have to set the dwell. When we put the HEI in it was like day and night. I know it was probably swapped out by a previous owner but still it had points in its' early days. When the smog police rolled in years later that's when the HEI got put in. But setting points and screwing with the dwell was a weekend of fun. I know my '74 had a HEI as well.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 11-05-2013, 10:25 PM   #12
teamssc
Thanks for the input. I was afraid this would become a religious discussion, points vs HEI, and I really was trying to avoid that as there are plenty of those threads on the forum. As I said I'll be doing a points disty just to do it, just to know I can, because that's what was in my 72 Nova. I know when HEI went mainstream I always wanted to drop one into the Nova but never did. Points, Dwell and all the rest weren't that big of a deal to set up. I don't know that I will stay the points ditsy, in fact I doubt it will. That doesn't mean I won't do it.
So back to my original question. What do I look for in a distributor (there's none in the for sale section here). There are multiple reasonably priced Accel and Mallory on ebay. Do I buy one that says good for SBC? What am I looking to avoid?
Old 11-05-2013, 10:32 PM   #13
INSIDIOUS '86
Originally Posted by teamssc View Post
Thanks for the input. I was afraid this would become a religious discussion, points vs HEI, and I really was trying to avoid that as there are plenty of threads on the forum. As I said I'll be doing a points disty just to do it, just to know I can, because that's what was in my 72 Nova. I know when HEI went mainstream I always wanted to drop one into the Nova but never did. Points, Dwell and all the rest weren't that big of a deal to set up. I don't know that I will stay the points ditsy, in fact I doubt it will. That doesn't mean I won't do it.
For a vintage distributor not many ran the access back then very much. The Mallory distributors were the hot ticket. Track cars would run dual points. Look for ones that have little shaft play. Although Mallory can still recondition them I'm sure.
Old 11-05-2013, 10:36 PM   #14
Sodell
Sodell's Avatar
I have to add;;;lol...I had a V8 Vega I built back in the day and I out a duel point dizzy in it...at least I could reach it. I am with INSIDiUOS, if you are going to keep it a while I would go with a Mallory Hey, you could throw on some bias ply tires too..
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 11-05-2013, 10:37 PM   #15
teamssc
I'm not sure what you mean? Accel instead of access?
Old 11-05-2013, 10:38 PM   #16
teamssc
Originally Posted by Sodell View Post
I have to add;;;lol...I had a V8 Vega I built back in the day and I out a duel point dizzy in it...at least I could reach it. Hey, you could throw on some bias ply tires too..
Hilarious .... well not really
Old 11-05-2013, 10:43 PM   #17
Sodell
Sodell's Avatar
8 Track??? sorry had to do it...
Scott
Old 11-05-2013, 11:02 PM   #18
teamssc
Now THAT is funny!
Old 11-05-2013, 11:24 PM   #19
geezer#99
geezer#99's Avatar
Go shoppin' on evilbay. There's several.
http://www.ebay.com/itm/1962-63-64-6...r#ht_150wt_813
Old 11-05-2013, 11:40 PM   #20
teamssc
Went to the Summit site and went through their configurations. They point to the Mallory Dual Point Distributor 2548201. Went to ebay and there are several in the $50 to $75 range.
Old 11-06-2013, 12:46 AM   #21
mrolds88
Something else to remember about this swap. Regardless of good/bad, fun/no fun, etc. You will need to put a resistor inline for the power feed for the ignition. Original points systems had a resistor power wire going to the coil.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 11-06-2013, 02:36 AM   #22
INSIDIOUS '86
Yes. Sorry sometimes my phone tells me what to type.
Old 11-06-2013, 08:25 AM   #23
xrcr
Still have points in my shovelhead, but access is a little easier. That being said I'm currently chasing Demons in my HEI.
xrcr is offline   Reply With Quote
Old 11-06-2013, 09:43 AM   #24
teamssc
Thanks for bringing that to my attention. I think this warrants a trip to the junkyard to pull some parts from an older Chevy so I can get the configuration right.
Old 11-06-2013, 10:11 AM   #25
manimal
manimal's Avatar
any points distributor for a Small Block Chevy OR Big Block Chevy will work...EXCEPT for the BIG truck 366/427.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
