Old 11-05-2013, 04:33 PM   #1
jamesclark
two questions
1st did i get a good deal i traded a 1996 maxima with blone motor and $1000 for 1972 c10 long bed has a irok 305
2nd what's a good 5 speed trans for it that will give better gas mpg its only gettin about 6 mpg now or other tips to get better
jamesclark is offline   Reply With Quote
Old 11-05-2013, 04:52 PM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: two questions
So, you went from a Nissan that did not run to a truck that runs, but gobbles gas like it is going out of style. Gas mileage improvement was zero or negative in this case. The fact that you can drive down the road is a plus. The old Camaro engine must have something seriously wrong with the way it is set up in the truck to get that low of a mileage number. I would check timing and the basic items to make sure there is nothing wrong there. As for a tranny, a six speed would be better, but the install could be a major issue if you do not have the right background or equipment. The IROC engine install, is it a complete install with all of the IROC parts, or is it just the block with the truck's components on it. (carb, etc...) If the engine is trying to run on the computer then there could be issues with how the computer was connected and the sensors are reading the exhaust and coolant temp.
Frank
piecesparts is offline   Reply With Quote
Old 11-05-2013, 08:47 PM   #3
jamesclark
Re: two questions
It has a 4 barrel carb don't thank the computer was installed
Old 11-05-2013, 08:58 PM   #4
mmiddle
mmiddle's Avatar
Re: two questions
Some of the early IROC's did have a carb. The TPI was actually an option that most had.
What gears are in the truck? What cam? 5MPG may be normal if the engine is seriously over cammed and crappy gears and so forth.
We need to know more about your truck to give pointer to get better mileage beyond a full tune up.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 11-05-2013, 09:05 PM   #5
jamesclark
Re: two questions
Original 3 speed to the truck and stock cam as far as i know
Old 11-05-2013, 09:21 PM   #6
mmiddle
mmiddle's Avatar
Re: two questions
Was it a 6 banger truck? Serial # starting with "CS"?
You probably have 4:10's in the rear... helps explain some of the 5 MPG.
Mark
Jesus is the Way!
Old 11-05-2013, 09:38 PM   #7
jamesclark
Re: two questions
Ok every thing i know is its a 72 c10 long bed (350 3 on tree) all is stock but the motor and swifter moved to floor
Motor is an 89 iroc 305 changed over to a edelbrock 4 barrel
