Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 11-05-2013, 04:49 PM   #1
studda
studda's Avatar
RHP-5 Multi-Piece Wheel Dangerous?
I looked at my 1 1/2 ton wheels and I noticed at least one one has the raised center section. It does appear to have a lock ring on the other side of the wheel though. It appears to be an RHP-5. Are they to be avoided like the RH-5 "widowmaker" wheels or is it just the true split wheels without lock rings? The rear wheel looks the same on the reverse as the front wheel pictured. This is the only one I noticed on the truck with the raised center section.
Here's a link to the various wheels as seen at stovebolt:
http://www.stovebolt.com/techtips/wh...dd_catalog.jpg
studda is offline   Reply With Quote
Old 11-06-2013, 08:30 AM   #2
buggy5872
buggy5872's Avatar
Re: RHP-5 Multi-Piece Wheel Dangerous?
If it has a lock ring on the outside of the rim it can safely be used. You still need to know what you are doing when changing the tire. The rim needs to be disassembled and checked to ensure it is in good condition to be used. It is not as dangerous as the rh5 but can be a danger if you do not know what you are doing. I pesonally do not use multipiece wheels. You have a tough bolt pattern to find used 22.5 wheels. The 6 bolt 22.5 are more common.
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 3100 with 59 fleetside bed
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker
Big Bertha Build
buggy5872 is offline   Reply With Quote
