Old 11-05-2013, 07:24 PM   #1
TBONE1964
Cluster King
TBONE1964's Avatar
350 engine accessory lot
Due to the fact that I have somewhat changed my direction on my 72, I am offering this lot of parts for sale. Everything in the photos was bought to bring my 72 engine compartment back to as stock appearing as possible. This collection took a while to gather. All parts (minus the carb) have been sand blasted and painted with engine enamel. Most everything you see here was purchased from a board member at one time or another.
Thank you for looking.
Here is a list:
LH / RH Ram's horn manifolds with new studs and mounting bolts, doughnuts and heat stove.
Pair of valve covers with fel-pro gaskets (7/32 thick)
All of the spark plug wire holders for the factory wires.
Air cleaner housing and adapter with hose and correct tower clamps
Q-Jet carb 7042210. Needs rebuilt and needs some linkage to be complete.
Complete set of AC brackets for a A6 compressor.
Set of PS brackets
Set of Alt brackets
Oil filler tube
Double groove water pump pulley.
Harmonic balancer pulley ( two piece AC type)
I am looking for $450.00 for the complete lot. I would rather not separate but will consider it if I get good offers for separate parts.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 11-05-2013, 07:27 PM   #2
mo
Re: 350 engine accessory lot
Great looking collection. I'm tempted. Good luck with the sale!
72 Cheyenne super swb 4x4
68 CST swb anniversary gold
67 custom swb 4x4
mo is offline   Reply With Quote
Old 11-05-2013, 07:31 PM   #3
TBONE1964
Cluster King
TBONE1964's Avatar
Thank you,
There is also a point style distributor and coil bracket that goes with this lot. It will need new parts such as points, condenser, cap and rotor but is in otherwise good shape.
Old 11-05-2013, 09:44 PM   #4
Rem701
If you consider separating I would like the spark plug wire holders
Rem701 is offline   Reply With Quote
Old 11-05-2013, 11:11 PM   #5
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Interested in Carb and valve covers.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 11-05-2013, 11:25 PM   #6
lawest
Int. in the accessory mounting brackets and the air cleaner parts.
69 K10 SWB Project Dream '69
2011 K2500 Silverado
Beat to fit, Paint to match
Dream '69 Build Thread
lawest is offline   Reply With Quote
Old 11-06-2013, 01:18 AM   #7
TBONE1964
Cluster King
TBONE1964's Avatar
PM sent.
Old 11-06-2013, 01:19 AM   #8
TBONE1964
Cluster King
TBONE1964's Avatar
Just the wire holders or do you want the shields also?
Old 11-06-2013, 01:23 AM   #9
TBONE1964
Cluster King
TBONE1964's Avatar
PM sent
Old 11-06-2013, 01:26 AM   #10
TBONE1964
Cluster King
TBONE1964's Avatar
Due to an overwhelming response, I will consider splitting up this lot. PM's have been sent to interested parties.
Tom
Old 11-06-2013, 04:46 AM   #11
Rem701
I would like the shields as well.
Old 11-06-2013, 07:36 AM   #12
DaHos
DaHos's Avatar
Tom, Interested in the "lot". please call me, thx, D'
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 11-06-2013, 08:26 AM   #13
TBONE1964
Cluster King
TBONE1964's Avatar
Dave,
Left you a message. Give me a call back. I will send you a PM with #'s
Thank you,
Tom
Old 11-06-2013, 01:14 PM   #14
Andrew S
If you still decide to split things up, I am interested in the pulleys.
Thanks-
Andrew
'72 K20
Andrew S is offline   Reply With Quote
Old 11-06-2013, 01:59 PM   #15
TBONE1964
Cluster King
TBONE1964's Avatar
Thanks-
Andrew
I will let you know soon
Thank you,
Tom
Old 11-06-2013, 08:26 PM   #16
DaHos
DaHos's Avatar
Tom, per our conversation "I will take it".
See u this weekend, D'
1967 C10 SWB
Old 11-06-2013, 08:34 PM   #17
TBONE1964
Cluster King
TBONE1964's Avatar
Thank you Dave,
The lot is sold.
Thank you to all that inquired.
Tom
