Rusty Nuts
what are these parts
My buddy is putting back together a 72 suburban. And ask me to tell him where these parts go that are left over. I told him where the top peice goes on the fender well and the bottom part on the right is for the jack. But the other three parts I have no clue. Or if they are even off the burb.Thanks for any help.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: what are these parts
Bottom left is accelerator pedal bracket. It bolts to the inside of the firewall.
the black right angle bracket is part of the transfer case side torque mount.
1990 Suburban Silverado 350, SM465 and 35" tires |
Upper right is the vacuum tank bracket that bolts to the A/C evaporator box.
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
![]() Join Date: May 2007
I believe the blasted looking piece, mounts to the side of the a/c housing, for the vacuum ball to bolt to, on a 4wd.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
Rusty Nuts
Ok thanks guys.
Rusty Nuts
Apparently the bottom left is for gas pedal but not for 67-72, i found info that says 1974-1999 because i cant see how it would fit. am i wrong? Thanks
![]() Join Date: Mar 2003
bottom right looks like a mounting plate for the jack
That looks like the right one to me. Fit's 71-72. Hold it up to the inside of the firewall where the pedal mounts. Line up the three bolt holes with the three in the firewall.
