Vent Glass Removal
How do I remove the vent glass from my '53? Can I easily remove the vent window trim or is it pretty permanent? The area pictured where the trim attaches to the door is the area in question. Will I have to drill out what appears to be a rivet? Also, how do I get the glass out of the metal trim? Thanks in advance for any help.
Re: Vent Glass Removal
The glass is just pressed in the frame with the gasket.
lub, yank, and pry it out New one goes back in the same way |
Thank you, that should do it.
![]() Join Date: Oct 2013
Chevy service manual says to hit it with gasoline to free it up.---Jack
That's it!
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 ![]() |
I used some mineral spirits and pried around on it with a screwdriver. It was in a couple pieces when it came out but it was already shot anyway. Ready for new glass now. Thank you all for the help.
do a good cleaning on the glass frame - make sure you get it rust free ( if there is rust)
also if you are using new window rubber - use warm water and dish detergent - soak the new stuff will make it go in easier --- good luck |
