Exhaust manifold bolts?
Where are you guys getting them from? I went to O'Reilys and Autozone and both want to sell me m10 x 1.5. I am under the impression that it's supposed to be a m8 x 1.25. They both told me I was wrong and those were ford bolts. I bought the m10 and they were indeed too big?
What's the right size and where do you guys get them from?
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265 |
meowMEOWmeowMEOW
Re: Exhaust manifold bolts?
From manifold to collector flange
or from head to header flange?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Location: Sunny, Florida, some might call it South Alabama
Seems like I ordered mine off of Amazon...or maybe they came with my headers...go to LS1truck, or LS1tech, and check in the for sale threads, I'm sure someone there can hook you up.
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
Boosted Member
M8 x 1.25 thread. Dorman part # 03413B GM part # 11518860
The earlier engines had bolts that fit a 10mm socket. The newer engines use bolts that fit a 13 mm socket.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Mine came with the headers, but they are indeed M8x1.25. ARP sells a set for $30
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
I should have mentioned it earlier. Yes, head to flange
Thanks for the help fellas, especially for part #'s ![]()
I've seen way too many factory exhaust manifold bolts broken on LS engines, I'd go with the ARP's...you can get them from Summit, JEGS, Speedway, etc.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
I actually put a small dab of anti-seize on the tips then check the torque every time I do an oil change. Takes another 10 mins and I rarely have one back out, but at least I know they'll be easier to get out of the aluminum when I need them to.
Boosted Member
^ LOL....damn man. Taking preventative maintenance to a new level.
I rip them down with the cordless impact, go out and beat on the truck till the manifolds are glowing red....rinse and repeat. Never broken a manifold bolt on any of the 6 LS swaps I've done. However it's weird how almost every swap engine I start with has at least one broken bolt...usually the one on the driver side closest to the firewall.
#10 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Thanks. Yeah I did. I Couldn't get the people at the store to find it with part number and all. Online shipping was more expensive than the bolts so I just went with the ARP from Jegs with free shipping.
Good deal....the studs/nuts were not cheap (stainless), about 125 for the set (ouch), but I will probably pull the headers once a season for blast/repaint. Longhorn
#13 |
Are there no Jet Hot coating companies in your area, or are you against coatings, seems like a lot of work
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#14 |
No coaters in my area , that I know of? As far as the work....its a labor of love
