Rochester 4 bbl carb squeal
hey guys got a 350 with the Rochester 4 barrel. and its got what i though was a belt squeal but turns out its the carb? time for a rebuild? or is it just a vacuum line? thanks!
1970 c20 cst 350/400 14bolt rear |
Wide n'Low
![]() Join Date: Jan 2007
Re: Rochester 4 bbl carb squeal
Ya know, I think I have one of those too,
Thought maybe it was just me.. Mine is a brand new old stock Edelbrock quadrajet. Not sure what to do about it, can't find any leakes etc..
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
i have a feeling its a vacum leak but i dont know much about carbs at all. im learning as i go. my secondaries also seem to not open which makes me think it might be a vacum leak.
scratch all that. was the belt. swap yours out if you haven't already
#5 | |
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
haha right on it was really driving me crazy for a few weeks until i finally got it
Wide n'Low
Well,
Can't blame the belts on mine, I ran it without any belts at all as a means to eliminate them.. Still have a sqeel / squeak.. Vacuum gauge doesn't indicate a leak that I can pinpoint.. Not sure what to do next. Only happens a 1/2 3/4 throttle
![]() Join Date: Mar 2012
sounds like it is just air flow going into the air horn on the top of carb, i had a 72 with a 307 before and every time you downshifted and stomped it , it would made a squeak or whine sucking air in,does it happen with the air cleaner off??
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Woops, i stand corrected, it was the port on the manifold for the transmission not a port on the carb, i had used the port on the carb then forgot to plug the fitting on the manifold.. so i plugged the carb port and went back to the manifold port and problem solved.
damit! spoke to soon. i tested it out again today and it still making that squeal with and with out the air cleaner. what did you do to fix the carb on the 307?
