Old 11-06-2013, 01:24 PM   #1
TheChief
73-80 side molding
can any one tell me if its possible to run the 73-79? side molding on a 82?
i just picked up a reg cab dually and the older trim works much better with the 2 tone paint job in planning on doing
this molding
thanks in advance
08 cc silverado dropped on 24's
82 1 ton c30 Dually
TheChief is offline   Reply With Quote
Old 11-06-2013, 01:27 PM   #2
notallthere
Re: 73-80 side molding
The only thing that may be awkward is the front marker light on the truck. It could be out of place but shaving it would solve that problem.
notallthere is offline   Reply With Quote
Old 11-06-2013, 01:32 PM   #3
TheChief
how about the rear fender?
82 1 ton c30 Dually
Old 11-06-2013, 01:36 PM   #4
notallthere
The rear marker lights stayed the same for all years so they will line up just the same.
Old 11-06-2013, 01:40 PM   #5
TheChief
I was talking about the moulding that goes on the rear fender
82 1 ton c30 Dually
Old 11-06-2013, 01:44 PM   #6
notallthere
The rear dually fender?
Old 11-06-2013, 03:00 PM   #7
TheChief
yea the curve molding there is it just a regular end piece? the one right before the marker light on the fender
82 1 ton c30 Dually
Old 11-06-2013, 06:20 PM   #8
notallthere
I should line up just like the one in the picture. Even on at 82.
Old 11-06-2013, 07:28 PM   #9
baclay9
Front fenders are shaped totally different.
baclay9 is offline   Reply With Quote
Old 11-06-2013, 07:56 PM   #10
79Betty
79Betty's Avatar
You're gonna have to swap doghouses for that to work. But that's not hard. All else will be fine
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 11-11-2013, 03:38 PM   #11
whited44
Front fenders and marker lights are different. Plus the trim pieces that attach to the dually flare are not made in the aftermarket and are hard to find in my opinion. The other bed pieces can be cut from a regular long bed fleetside.
whited44 is offline   Reply With Quote
Old 11-11-2013, 03:41 PM   #12
TheChief
Thank you
82 1 ton c30 Dually
