Old 11-06-2013, 03:38 PM   #1
Jahloha
Jahloha's Avatar
Ordering New Springs/Lift Inquiry
I have a 1970 C20 which has stoked everything. I am a tall person and would like to level out my truck with a small lift (1'' or 2'').
I am new to suspension, but have been reading that I can have new springs made to provide this height. If this is true, what other parts would I need to alter, in order to have these springs work correctly?
Or can I simply replace stock springs with new springs?
Thanks for all the help, I appreciate this forum so much.
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 11-13-2013, 09:06 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Ordering New Springs/Lift Inquiry
Are you trying to raise the front, rear, or both?
New springs would be a good start.
Keith
Convert to disc brakes.
Old 11-13-2013, 11:28 AM   #3
Jahloha
Jahloha's Avatar
Lolife:
I am wanting to level out the front with the back. I am taller and need a stronger stance for ease of entering/exiting the truck. It has a small block in it.
Also, while I have you, if you don't mind...I have been reading a ton about front disc brakes and appreciate all your threads. I have the 70 front crossmember and wanted to ask you a question...
I am not super excited about buying a conversion kit, I would prefer to buy the front end and back end from a truck that has the disc brakes, but is a direct bolt in situation.
Does that exist for my truck? I read a lot of material but because I have never done this, I second guess what I am understanding. So if I were to do a front and rear swap, what years are direct bolt ins?
Thanks for helping me on both questions.
-JASON
Old 11-13-2013, 11:45 AM   #4
Jahloha
Jahloha's Avatar
Or am I thinking off base by wanting to swap front and rear ends, but should really do the kits?
-JASON
