Old 11-06-2013, 04:15 PM   #1
jbearden
Will chevell rear springs work to lower the truck?
Ive got a 67 c10 with coil springs all the way arround. l have already lowered it 2 in the front and 3 in the rear, and i want it lower. I am trying to go as cheap and as low as possible. I have heard Chevelle rear springs will bolt right up and drop the rear arround 4 inches.
Is it true, and if it is what model chevells?
jbearden is offline   Reply With Quote
Old 11-06-2013, 07:21 PM   #2
JimKshortstep4x4
Re: Will chevell rear springs work to lower the truck?
68-72 "A" body springs will work, (Chevelles, Buick Skylarks, Olds, etc.) and it will lower your truck. My friend put them on his stepside and it lowered the rear by 2-3". It will cut the hauling capacity down but the truck rides pretty nice with the springs in it.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-06-2013, 07:44 PM   #3
BMERDOC
BMERDOC's Avatar
I'm not sure how much it'll lower it but I'd look for wagon or El Camino springs.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 11-06-2013, 07:50 PM   #4
leddzepp
Moderator
leddzepp's Avatar
I would just buy the proper lowering springs. I heard Jeep wrangler springs did the same thing...4" drop. Nope, not at all. Same height, just a weaker rate and a bouncier ride.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 11-06-2013, 09:48 PM   #5
jbearden
Thanks guys I think I'll give them a try.
Old 11-11-2013, 11:25 PM   #6
kelbystanley
Used them on mine. Load capacity went way down but I dont' haul with mine anyways and it rides like a caddy on 22's!
kelbystanley is offline   Reply With Quote
Old 11-12-2013, 09:36 AM   #7
Jurassic-1
Jurassic-1's Avatar
I have used 2002 Jeep Wrangler springs. The truck sits about 1 1/2 - 2 inches lower and rides great. These springs are readily available since there are quite a lot of lifted Jeeps in my area. You may be able to get them real cheap from an off road shop. (Just another option).
Jurassic-1 is offline   Reply With Quote
Old 11-12-2013, 10:54 PM   #8
sanford&daughter
sanford&daughter's Avatar
Rear coil springs from a 96-99 ford taurus station wagon will drop ya 4.5 to 5 inches
sanford&daughter is offline   Reply With Quote
