Old 11-06-2013, 07:58 PM   #1
FLYNAVY30
4L60E to factory column shift?
Anything special required to mate the factory column shift to the 4L60e? Drive train gets dropped in tomorrow!
Thanks!
FLYNAVY30 is offline   Reply With Quote
Old 11-06-2013, 08:19 PM   #2
jks67ss396
Re: 4L60E to factory column shift?
nope... mine works just fine with the stock linkage!
jks67ss396 is offline   Reply With Quote
Old 11-06-2013, 08:27 PM   #3
FLYNAVY30
Awesome, thanks
Old 11-06-2013, 10:11 PM   #4
Hart_Rod
Hart_Rod's Avatar
If you need more room for exhaust, Lokar sells a kit. OBTW, what squadron are you attached to?
Hart_Rod is offline   Reply With Quote
Old 11-06-2013, 11:09 PM   #5
FLYNAVY30
ok cool, thanks for the info! Right now, HM-14...prior VT-10 and HM-15
Old 11-06-2013, 11:19 PM   #6
Hart_Rod
Hart_Rod's Avatar
Aircrew or Pilot?
Old 11-07-2013, 06:09 AM   #7
4x4toy
I have a few questions regarding the use of stock column shifter. How does the 3 speed shift gate in the column play with the 4 position gear selector in the trans? Are you guys able to pull shifter down to lowest position? Does neutral line up correctly?
04 Yukon XL 2500 w/ Quadrasteer
61 Chevy C60, 261 inline six
86 Chevy C20 2wd, Banks 6.2
05 GMC Sierra 2500hd Duramax
4x4toy is offline   Reply With Quote
Old 11-07-2013, 07:59 AM   #8
FLYNAVY30
Pilot
Old 11-07-2013, 08:53 AM   #9
Hart_Rod
Hart_Rod's Avatar
Pilot
When did u go through the HTs? I was an IP in HT18 from 2000-2007.
Old 11-07-2013, 10:33 AM   #10
jks67ss396
4x4
I can get all gears on the 4l60 with the stock shifter. As far as lining up with the pointer, i dont have a pointer on my column yet, so i dont know if it lines up but it does get every gear
Old 11-07-2013, 10:44 AM   #11
FLYNAVY30
Winged Jun 2005 HT18....Maj Courey was my onwing
Old 11-07-2013, 11:19 AM   #12
Hart_Rod
Hart_Rod's Avatar
Too funny, I was in HT18 at the time, but was Wing HT Stan Officer. I've known Joe for a long time. Matter of fact, we both currentley work at the TW5 wing building. Small world, . I used to drive my 48 everyday, maybe you remember it.
Old 11-07-2013, 12:31 PM   #13
FLYNAVY30
Ha, that's awesome! I do remember that truck....tell Maj Corey that Greg Paules said hello!
Old 11-07-2013, 01:08 PM   #14
Hart_Rod
Hart_Rod's Avatar
Will do! You may have seen my suburban parked up here to before I started restoring it...
Old 11-07-2013, 02:55 PM   #15
Custom 68
Custom 68's Avatar
The only problem I had was mentioned above and when I redid my exhaust I didnt get it low enough to start with and my linkage interfered with the pipes. I could not go into low. That is really not necessary since the computer does what it wants to anyway lol. I did fix it but thought about using the Lokar cable it looked much cleaner. There seems to be enough "slop" in the shifter I was never sure by looking at the pointer what gear I was in. I normally just left it in OD and went for it.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 11-07-2013, 03:36 PM   #16
Hart_Rod
Hart_Rod's Avatar
The gate isn't in the column (except for park), it's done throught the tranny. You can play with the adjustment for the different positions, mines not perfect, but it's close. No problem on mine going into all gears.
Rob
Old 11-07-2013, 06:19 PM   #17
Custom 68
Custom 68's Avatar
I had seen a few years ago a 4 speed plate for the column. So it had the OD spot as well as the others. I recently looked and coldnt find it I am not sure if it went into production.
But Yes neutral lines up so you can start your truck in neutral and park as well as having reverse lights. again sometimes they are a little sloppy but always worked.
Dave
Dave
Old 11-07-2013, 06:41 PM   #18
Hart_Rod
Hart_Rod's Avatar
Dave
http://www.ididitinc.com/accessories...icators_Acc-17
Old 11-08-2013, 10:51 AM   #19
Custom 68
Custom 68's Avatar
Thanks Rob, those are pretty cool. I am now running a T56 so I don't need them but maybe somebody else can use these.
My truck has tilt so I know those are different and not sure if those are a direct swap or not.
anyway thanks for the link.
Dave
Old 11-08-2013, 12:06 PM   #20
Smurfeh
Pilot
God help us all.. they are multiplying like rabbits.. hahaha everyone wants to fly'em no one wants to fix em.
Smurfeh is offline   Reply With Quote
Old 11-08-2013, 12:31 PM   #21
FLYNAVY30
Especially in my case....wrenching on a -53 is an exercise in futility
Old 11-08-2013, 05:29 PM   #22
Smurfeh
DHC-7 all the way my friend!
