Old 11-06-2013, 09:18 PM   #1
rou
I can see the finish line!
rou's Avatar
Help -th400 slipping in D engages in 1&2
The drivetrain sat for about 2 years during our resto. Got her running last month and ran great but leaks at the pan. I kept adding tranny fluid until I could change the pan seal, but two days ago it stopped engaging in Drive. It did work in 1 and 2. I changed the seal/filter and refilled fluid, still same problem. Slips badly in Drive but will catch in 1 or 2. Before I go to the transmission guy tomorrow, I thought I would go to you guys for suggestions.
Thanks, Rou
1971 C20 402BB
In the process of a rebuild now
Our first Build - '71 C20 LWB
rou is offline   Reply With Quote
Old 11-06-2013, 10:41 PM   #2
WorkinLonghorn
WorkinLonghorn's Avatar
Re: Help -th400 slipping in D engages in 1&2
Go to the transmission guy tomorrow.
I'm no expert but in my limited experience, regardless of the initial cause, once a transmission "slips badly in Drive" it is toast.
If it just isn't shifting up, then that could be an easy fix, but if the 2-3 shift results in slippage, it is done imo.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 11-07-2013, 10:48 AM   #3
rou
rou's Avatar
Transmission guys says I have a forward shift issue. He is going to rebuild for $1000.
1971 C20 402BB
Old 11-15-2013, 11:59 PM   #4
luvbowties
luvbowties's Avatar
Smile Re: Help -th400 slipping in D engages in 1&2
In our area, building a TH400 is a bit cheaper than $1000. Actually, it is one of the cheapest autos, presently used, to re-build and still have a strong, serviceable tranny.
Sam
luvbowties is offline   Reply With Quote
