11-07-2013, 01:10 AM | #1 |
200r4
Has anyone installed 200r4 in C10? I have a '72 Super Deluxe shortbed w/ 350/350 combo. I have a friend giving me a 200r4 out of a '86 Pontiac 2plus2.
11-07-2013, 01:26 AM | #2 | |
Re: 200r4
We have one in our truck,(200-4R) seems to be doing just fine so far.... Alot of install images of the transmission in our Google albums... Any questions feel free to ask... Scott
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi, My 68-SWB Photo Build Thread All my Google Albums |
11-07-2013, 03:01 AM | #3 |
Re: 200r4
Thanks, all your info is useful. I have a quadrajet, will I have to change any linkage for carb?
11-07-2013, 06:51 AM | #4 | |
Re: 200r4
I used the same location on the carb that the TH350 cable was hooked to, just had to change the pin to a clip type for the 200-4R cable to clip to. Just make sure the cable is 100% tight at full throttle
Mark 71 C10 Cheyenne 12 Aprilia RSV4 |
11-07-2013, 08:44 AM | #5 |
Re: 200r4
A 200R4 is an OK transmission, but will not hold up to high power in bone stock form. Keep in mind that GM never put one behind a big-block. The biggest stock engine in front of a 200R4 was a "mighty" 307 Olds. If you have it rebuilt with some of the upgrades it will be fine. If you want an overdrive and don't want to build it first, better get a 700R4. You can get a carb bracket for the TV cable from the car it was in or a Monte Carlo in the same year ranges. DO NOT install a 200R4 or 700R4 without hooking up the TV cable before you ever start it.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
11-07-2013, 10:43 AM | #6 | |
Re: 200r4
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
11-07-2013, 10:57 AM | #7 | |
The Older Generation
Re: 200r4
- I put one in my Suburban, behind a 350 crate engine. I pull the trailer with it but the heaviest thing I have hauled so far is a complete 3/4 ton frame. I used the BowTie Overdrives TV cable kit and lockup kit. It just turned over 3000 miles and no problems so far. LockDoc
11-07-2013, 12:12 PM | #8 | |
Re: 200r4
Austin 2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked) 2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l |
11-07-2013, 12:22 PM | #9 | |
Re: 200r4
I'm not saying don't use a 200R4. I am saying that it might not last long if you take a used one out of a tired V6 or 305 A-Body and put it in a heavy truck with a 350/350 and trounce on it.
11-07-2013, 01:21 PM | #10 |
Re: 200r4
Everyone always talks about the 2004R being so strong because it was in the Grand National, the real reason GM used the trans is that it was the only overdrive trans they had that would bolt up to the Buick block, not because it is an amazing trans.
11-07-2013, 01:47 PM | #11 | |
Re: 200r4
11-07-2013, 02:03 PM | #12 |
Re: 200r4
x3 bowtie overdrives... used them before and i've just ordered another 200-4r with all their accessories (crossmember, tv setup, lockup wiring) for my 1968 with a 350 smallblock.
bowtie overdrives and other builders modify/beef up the 200-4r to respectable/usable/reliable performance levels. |
11-07-2013, 02:09 PM | #13 |
Re: 200r4
11-07-2013, 02:44 PM | #14 | |
Re: 200r4
Well, I don't read it a lot but you would think I would have noticed it for as long as I've had it on there... Thanks for the heads up. LockDoc
11-07-2013, 03:06 PM | #15 |
Re: 200r4
I know right? I have read it at least a dozen times cause I always think it is a perfect saying anyway back to a 200-4r transmission
11-07-2013, 07:41 PM | #16 |
Re: 200r4
Thanks everyone. I will check on the kits. I knew I would have to add something for the lockup. I can't get my hands on a 700r4 right now, $$ is tight. I'm a "state" employee, elementary school counselor and Driver's Ed. instructor. The 200r4 is free, so my only cost will be the two kits mentioned. I'll check with my friend about a carb bracket. He has owned over 20 of the '86 Grand Prix 2+2's, so I know he has one somewhere. My 350 is stock and I don't plan on doing any upgrades. I would love to have a 5.3 at some point.
11-07-2013, 07:57 PM | #17 | |
Re: 200r4
With the Bowtie TV kit you get a bracket. LockDoc
11-07-2013, 10:29 PM | #18 |
Truck and auto performance nut
Re: 200r4
had a 200-4r in my truck before the 4L85e. Mine wasn't built strong enough to handle my motors torque/horsepower even tho it was supposed to be. Was OK in 1st and 2nd, but couldn't handle 3rd at WOT. That said....built properly they are a great choice for these trucks...will fill the spot a turbo350 was quite nicely.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
11-08-2013, 08:13 AM | #19 | |
Re: 200r4
11-08-2013, 11:03 AM | #20 |
Re: 200r4
Thanks Markdtn, grateful for everyone's advice.
