Old 11-07-2013, 02:47 AM   #1
Vova
Gauge cluster upgrade
My truck came with the basic cluster ( speedo and gas). The PO install three aftermarket gauges under the dash (volt, temp, and oil).
I want to install a stock cluster that includes the volt, temp, and oil.
I know I'll need to replace the temp sending unit with this http://www.americanautowire.com/shop...ding-unit-5032
Will I need to do anything else or should the volt and oil be plug and play?
Vova is offline   Reply With Quote
Old 11-07-2013, 03:15 AM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Gauge cluster upgrade
You will need to modify your existing wiring as well. Gmcpauls website has detailed instructions on how to do it. This came up recently here as well, but I can't seem to find the thread. The oil gauge is mechanical and you will need a hard line for it. Post a wtb on the parts board and I'll bet randy or someone else has one for sale.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 11-07-2013, 03:21 AM   #3
Vova
The aftermarket gauge I have is mechanical so I just need the fitting that goes on the stock gauge.
Thanks for the help.
Old 11-07-2013, 04:13 AM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
See if this helps, it's a long thread but it is very informative.
........http://67-72chevytrucks.com/vboard/s...d.php?t=564505
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-07-2013, 11:34 AM   #5
Vova
Very helpful and seems pretty straight forward now. It should probably be in the FAQ.
Thanks!
Old 11-07-2013, 11:49 AM   #6
TBONE1964
Cluster King
TBONE1964's Avatar
Thanks!
If you need any help with a Cluster or cluster parts, let me know.
Thank you,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 11-07-2013, 12:41 PM   #7
ksshane
ksshane's Avatar
I needed this information as well... Saving this post.
71 swb 350/4sp manual 5/7 static drop
ksshane is offline   Reply With Quote
Old 11-07-2013, 12:47 PM   #8
Carl Spangler
Carl Spangler's Avatar
Contact TBone (see post in thread) for your cluster rebuild.
cheers
JohnG
Carl Spangler is offline   Reply With Quote
Old 11-07-2013, 02:13 PM   #9
Vova
Thank you,
Tom
Thanks I'll let you know once I hook it up this week. Ordering the sending unit today.
Do you have the piece that threads the oil pressure line into the gauge?
Old 11-07-2013, 04:09 PM   #10
Vova
Will this work on my cluster?
http://www.ebay.com/itm/1969-75-CAMA...-/350535840207
Old 11-14-2013, 03:37 AM   #11
Vova
How do you remove the individual pins/wires from the cluster plug?
Old 11-14-2013, 08:23 AM   #12
Andy4639
Old member
Andy4639's Avatar
Wink Re: Gauge cluster upgrade
Small screw driver pushed in from opisite direction of wire. The metal clip has a tang on it. Depress it and pull it out by the wire.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-14-2013, 10:50 AM   #13
TBONE1964
Cluster King
TBONE1964's Avatar
Did you get the parts you need for your oil line? You can get the copper line kit at most parts stores for around $10 - $12.00 that should have all the fittings you need.
Good information from Andy on removing the terminals from the connector.
Old 11-14-2013, 11:47 AM   #14
Vova
Thanks guys. Going to stop by the auto parts store today...
Old 11-15-2013, 06:00 PM   #15
catch2otwo
If you haven't bought your temp sender yet, I just bought mine from www.lectriclimited.com. Found them searching for temp gauge info on here.
catch2otwo is offline   Reply With Quote
Old 11-15-2013, 06:19 PM   #16
Vova
Do you have a part number? I called them last week and the lady I spoke with said they didn't have a unit for a 70-72.
Old 11-15-2013, 08:50 PM   #17
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
I bought my mechanical oil gauge copper tube and fittings from Classic Parts. It works great on my 1981 and will fit 67-72.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 11-17-2013, 09:58 PM   #18
Vova
Having a hard time finding this adaptor. The small size thread is 5/16-24.
Does anyone know that the gauge cluster thread is?
Old 11-17-2013, 10:37 PM   #19
hugger6933
I know that changing those pins has to work, but it didn't for me. I put a cluster in my 68 GMC that was a brand new [rebuild] by a member on here that does real nice work. I followed the instructions to the T and even took more time than I should have doing it. I had a different cluster plug and changed over to and used some pins from it to the ones that had to be added. When I got done all that worked was the speedo and it made a noise every time it came to a 0 on the tenths side! I only drove it about ten miles after I put the tac/vac in it [and a tilt at the same time] but it is next on the list to come to the shop for frame-off/swap rebuild as a short truck any way.So maybe then I will get it figured out. I have another truck in the shop now plus another inline to be built, and I have tach dashes for them all So maybe I can find out what my problem is/was with the other. I know it has been done to death, other have done it right? Jim
hugger6933 is offline   Reply With Quote
Old 11-20-2013, 02:14 AM   #20
Vova
The size on the backside of the gauge is 7/16-20.
I can't find the adaptor in the auto parts store?
Any suggestions?
Old 12-06-2013, 08:55 PM   #21
Vova
What does the clip that connects to the temp sending unit look like?
