11-07-2013, 11:05 AM | #1 |
Is this normal- Clutch linkage
Specifically where the mechanism pivots on the ball stud attached to the barcket attached to the block on the left.
11-07-2013, 11:15 AM | #2 |
Re: Is this normal- Clutch linkage
Looks like it to me. Actually looks a bit bent in the picture. My V8 has a much stronger looking setup than that.
I don't have any pictures for you, but someone else may |
11-07-2013, 11:31 AM | #3 |
The Older Generation
That's why it is a ball stud, so it will take up any differences in component position and engine movement. That looks like it may be a little excessive but bad engine or transmission rubber mounting pads could cause that. LockDoc
11-07-2013, 04:12 PM | #4 |
I agree with doc above, check your engine and trans mounts for excessive wear
11-11-2013, 02:50 AM | #5 |
Mine looks identical and I was going to post this same question. Replacement parts for the Z bar don't seem to be available. Mine is still working well, just don't like how it looks. Haven't had a chance to investigate though.
