Post Whore
![]() Join Date: Mar 2013
Anybody here with tricked out chevy 6 cylinders?
Hey there, My name is T.J. and I am from the 60-66 chevy trucks board. There we have a thread entitled "Tricked out chevy 6 cylinders" thought it would be neat to see one here to, if there isn't one already. But I would love to see some and just for fun I will start with mine. 1966 chevy 292. Thanks.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Post Whore
Re: Anybody here with tricked out chevy 6 cylinders?
Here's another....
Very nice!
check out inliners.org
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Post Whore
That's a beautiful 6! Nice job!
Thanks, I've been there many a time! ![]()
Nice looking engine, but please take some time to clean up that wiring on the battery, looks like a short ready to burn it to the ground.
#8 | |
Jimi J from I-Oh-Way '57 Panel 3105 Met this deer... Roof Swap on my Panel Jim's Bread Truck |
I know it's not much, but here was my 216 after I cleaned it up.
Orrie I assume you just having some fun, truck not wired completely in that photo.
![]() ![]() Join Date: Nov 2008
I've posted this one before. It's not mine, it used to belong to member, N2Billet. It's a 250 and was in a '67-'68 short fleet he used to own. I'm still very impressed by it.
If my '55 had come with a straight six I'd have kept it and dolled it up as close to this as I could have. They're just unique anymore and cool to own
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
nice engines boys. I almost hot rodded out a 250 inline for my 56 because it's so out of the norm to see one with an inline still in it. There's nothing more I love than walking up to a car or truck at a show and seeing something different under the hood
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
#13 | |
Looking at the photo it is probably a project still in the works since the terminal is disconnected and wiring is temporary.
#14 |
#15 | |
When I was a small kid my Dad had two different AD trucks. (The years that had door handles that turn, not push buttons - what years are those?) The 1st one was his 1st truck, a bit of a beater. He bought it on a shoestring budget and he re-ringed the engine over a weekend so he could use it for work on Monday. In his haste to get it running he forgot to install the front motor mount bolts! Took it out to test drive it and goosed it. The engine rose up enough that the fan blades cut THROUGH the hood!! ![]() Scared the POOP out of us both! Needless to say, it totally effed up the hood. ![]()
#16 | |
Thank you for the concern, that photo was old and everything is neat and clean these days. I do appreciate when someone does point out something that may be a problem, hope I did not offend you. |
#17 |
#18 |
Nope, I'm good, I wanted to make sure you knew I was not just being critical. Now lets all get together and sing Kum BI Yaaaa
#19 |
425hp409
![]() Join Date: Oct 2008
A 235 in one of my customer's 50 1/2 ton. We rebuilt the engine with a little bump cam, installed independent front suspension, removed the granny 4 speed and closed driveline, installed a Tremec 5 speed and a 12 bolt rear diff.
The engine has an Offenhouser intake with two carbs and a Fenton split exhaust manifold running duals. The truck runs and drives like you would expect from a small block V8.....
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
#20 |
![]() Join Date: May 2011
I didn't know a 6cyl. could look so FINE! It leaves an incredible amount of room!
'72 Ford Bronco project(July 17 2021-?) https://67-72chevytrucks.com/vboard/...d.php?t=828015 59 Apache (sold 6-25-2021) 67 Ford Mustang (re-restored after Harvey) 1968 Jeep Cj5 (2-8-2020 to present) 1992 Jeep Yj (8-17-20 to present) (Jurassic build) www.Classiccarsandtools.com |
#21 |
Any GMC 6 bangers out there done up? aka the long block
#22 |
Waiting on the GMC 6 cyl. I have a 270 with the better head in my 450 GMC firetruck I'm wanting to hop up a little. So far just converted to 12 volt and put Pertronix Ignition and coil in. Haven't cleaned up much other than hose off.
#23 |
Pic of as now.
#24 |
#25 |
Don't have any pics nor is it tricked out yet. I have in my poses in a 292 I want to setup for a 49 fastback.
