11-07-2013, 02:22 PM | #1 |
coolant temp sending unit location PICTURE PLEASE
Okay dumb question but would like to ask as I want to fix my temp gauge so it will work. but where is the location of the coolant sending unit I have I think found the wire that goes to the unit (it is melted and hanging so I cant track it) I really havent looked for the unit. I would like to know where it is so I can fix it today and I have looked on here trying to find pictures of the location and cant find nothing please help. I know it is probably somewhere obvious. if someone can take a pic to show me where and what it looks like that would be great.
GMC Jimmy and Chevy Blazer the real mans convertible. |
11-07-2013, 02:32 PM | #2 |
Old member
Re: coolant temp sending unit location PICTURE PLEASE
Drivers side of engine between #1 & #3 spark plug.
Should look like this.
11-07-2013, 02:36 PM | #3 |
SWEET thanks
11-07-2013, 02:37 PM | #4 |
Old member
No problem.
11-07-2013, 02:40 PM | #5 |
Florida Edition
I put mine in the intake to keep it from picking up heat from the exhaust. That's it by the thermostat housing, reads perfect there.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
11-07-2013, 02:50 PM | #6 |
Thanks I will also check if its there as well cause mine has an Edlebrock manifold too
11-07-2013, 04:23 PM | #7 |
Thanks For The Help Guys Just Found Out It Was Disconnected That's All But Wouldn't Of Found It Without Help
