Old 11-07-2013, 03:12 PM   #1
18436572GMC
18436572GMC's Avatar
4.11 gears and 287/75/16
What would rpms be at 70 mph with this gear tire combination and an sm465
Real trucks have a clutch. Please inform automakers.
1972 GMC, K25, 383 stroker, SM465, NP205, Eaton HO-72
18436572GMC is offline   Reply With Quote
Old 11-07-2013, 04:10 PM   #2
kwmech
Re: 4.11 gears and 287/75/16
3000 plus, The 285/75 is about 31'' tall. I've got the same tire on my 68 with 3.73s and a big block........I put in an overdrive
Old 11-07-2013, 05:31 PM   #3
18436572GMC
Thanks for the response. I am debating a lift and 315/75/16. I figure that would run better with 4.11s and no overdrive
Old 11-07-2013, 05:51 PM   #4
budman k20
1972 K20
My Cooper 285-75-16's are 32.7 inches in diameter per the manufacturer specs?
With a turbo 350 70 mph is about 3200rpm per the factory tach should be close since I have a 2800 stall.
A rpm calculator puts the RPM at 3035 for an auto and 2956 for a manual trans based on tire diameter of 32.7"
budman k20 is offline   Reply With Quote
Old 11-07-2013, 05:55 PM   #5
18436572GMC
What is your ring and pinion ratio?
Old 11-07-2013, 06:17 PM   #6
budman k20
1972 K20
Sorry,
Factory equipped with 4:11 3/4 ton 4x4
Old 11-07-2013, 06:19 PM   #7
18436572GMC
thanks
Old 11-14-2013, 10:47 PM   #8
18436572GMC
ttt
Old 11-15-2013, 09:40 AM   #9
Yeah,just under 3 grand is accurate with manual & 4.10s. 285/75-16s run between 32" & 33". 235/85s are closest to original 7.50-16s,which are more like 31".
Old 11-15-2013, 03:27 PM   #10
Cali72K20
Cali72K20's Avatar
budman k20
you have about the same set up as mine:
TH350 / 4:10 gears / 265/75R16
and mine is at about 4500 RPM's @ 65 mph.
Does the factory tach make a difference?
I have a 350 engine with a 5k tach, that is what is in it now, i have seen an 8K tach in others.
Cali72K20 is offline   Reply With Quote
Old 11-15-2013, 06:41 PM   #11
Sicklajoie
The Niner
Sicklajoie's Avatar
Originally Posted by Cali72K20 View Post
budman k20
4500?? You sure about that?
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 11-15-2013, 10:09 PM   #12
jocko
jocko's Avatar
18436572GMC, spot on on the 3000 estimate - it's just a hair under that for your tires, like Tim mentioned. If you switched to the 315s, your 70 mph rpm would drop to 2790, so, a little reduction.
Budman - As for SM465 - I might be wrong, but thought it had a 1:1 high gear (?) - if so, then it would be the exact same rpm at 70 as a TH350 or TH400.
Cali72K20, something not quite right in your numbers there - 4500 is not correct for the combo you listed. Perhaps incorrect speedo gearing - have you double-checked your speedo with a gps? Or perhaps different rear end gearing than you think. I have the exact same combo on 2 trucks (TH350, 265/75/16, and 4.10s) and 65 mph = approx. 3000-3100 (per truck and per calculator). It's also possible that your tach is out o whack. Factory tach was 5K, some folks stuff aftermarket or other vehicle gm 8K tachs in. I think LMC makes an 8K tach kit also.
Old 11-18-2013, 06:36 PM   #13
budman k20
1972 K20
Jocko,
It is true that a SM465,Turbo 350 and 400's have a 1:1 final drive ratio but the automatics don't have lock up TC's so that is why they have higher rpms at a given speed. My truck rpm is a little higher at 70 mph due to the TC having a higher than stock stall speed.
Old 11-18-2013, 06:47 PM   #14
Cali72K20
Cali72K20's Avatar
Is a 5K tach for a big block and 8K tach for small block? I drove it again @ hwy speeds and it is about 4500 @ 65-70 MPH.
Old 11-18-2013, 06:49 PM   #15
Cali72K20
Cali72K20's Avatar
the tach did not work when I got it, the speedo didn't work either. I had to splice the tach wiring to get it working. The speedo cable was broken/cut, that was an easy fix. It does have a Mallory HEI in it from the PO.
Old 11-18-2013, 07:16 PM   #16
Cali72K20
Cali72K20's Avatar
The harness in the engine bay is new and has the tach wiring incorporated in it, the wiring under the dash looks OEM and the connector to the tach port in the fuse block was corroded beyond repair, all I did was splice a new connector from LMC truck.
Old 11-18-2013, 07:21 PM   #17
Cali72K20
Cali72K20's Avatar
the speedo is dead on according to local police signs that show your current speed.
Old 11-18-2013, 07:29 PM   #18
RANDY COX
RANDY COX's Avatar
I'd like to run a 33x9.50-15 with 373's would be good to run..that would help with rpm's some.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 11-18-2013, 07:30 PM   #19
budman k20
1972 K20
Cali72K20
The factory tach's are known to be inaccurate that is why I mentioned I have a factory tach. You really need to know what your speed is using a gps source. It is very possible that your truck has 4:56 gears and with an auto the rpms you are reading from the tach could be close. Yours still sounds high but that could be from an inaccurate factory tach. Another possibility is you have a 6 cylinder tach. All the factory tach's I have seen are 5K. It's a popular thing to put a 8K Camaro tach in the truck dash if you have a performance engine.
Old 11-18-2013, 07:39 PM   #20
Cali72K20
Cali72K20's Avatar
Thank you budman k20!
I need to pull off the diff covers and check them to verify what gear ratio I actually have. The tach does look original but I don't know for sure. Thanks again,
casey
Old 11-18-2013, 07:55 PM   #21
jocko
jocko's Avatar
Factory is 5k for all.
