Old 11-07-2013, 07:57 PM   #1
Jahloha
Jahloha's Avatar
Help Identifying Rearend
Hey Team:
I am doing a lot of reading and coming to the realization that I need to know what rear end I have...from what I read, I believe I have an Eaton.
Please help me identify this rear end, also what are some pros and cons to this particular model?
I am planning a dd restoration and want something that isnt harsh on mpgs, but also can handle the occasional 4000 lb trailer pull.
Mahalo!
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 11-07-2013, 08:06 PM   #2
Jahloha
Jahloha's Avatar
Re: Help Identifying Rearend
Also, I plan on putting a 700r4 in with probably the 292 hp cpp crate engine. If that helps your analysis.
-JASON
Old 11-07-2013, 08:21 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Yes, that would be the Eaton, probably an HO52. I think parts are getting hard to find for them, especially drums if you need them.. Most of them were 4.10's or 4.56 gears. If it is a 4.10 that wouldn't be too bad with the 700r4.
LockDoc
Leon
Old 11-07-2013, 11:06 PM   #4
Jahloha
Jahloha's Avatar
LockDoc
LockDoc or others:
What do people usually swap out for, if they have this model Eaton. I am unfamiliar with gears in differentials, but from what I can gather, 3.73 is best for the 700r4.
Is that correct? If so, what rearend would I ideally need to find?
-JASON
Old 11-08-2013, 12:30 AM   #5
LockDoc
LockDoc's Avatar
Originally Posted by Jahloha View Post
LockDoc or others:
I'm not really up on all of the rear end choices but I put a Dana in my Suburban. Maybe some of the other members will chime in here...
LockDoc
Leon
Old 11-08-2013, 02:31 AM   #6
SKELLY4x4
SKELLY4x4's Avatar
I've heard that the 14bff parts will work in the Eaton.
1972 chevy k20 long bed 4x4
1990 chevy K5 blazer
2001 chevy 2500 hd 4x4
1999 chevy 1500 4x4
SKELLY4x4 is offline   Reply With Quote
Old 11-08-2013, 02:33 AM   #7
SKELLY4x4
SKELLY4x4's Avatar
And the Eaton is a bad ass mofo. Nothing wrong with it.
1999 chevy 1500 4x4
