View Poll Results: Keep the Inline Turbocharged 250 or Swap in a 5.9L Cummins | |||
Turbocharged 250 | 34 | 75.56% | |
5.9L Cummins | 11 | 24.44% | |
Voters: 45. You may not vote on this poll |
11-07-2013, 11:50 PM | #1 |
Keep my Turbocharged 250 or swap for a 5.9L cummins????
So This past weekend cruising around I found and bought 5.9L cummins and trans combo..... So which leads me to my next question.... Do I keep my very unique Turbocharged 250 with a blow through setup, or do I sell it and swap in this 5.9L Cummins? Thoughts, comments, opinions welcome!
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
11-08-2013, 12:06 AM | #2 |
2WD Jimmy
Re: Keep my Turbocharged 250 or swap for a 5.9L cummins????
I love the six, so that's what I voted for. I guess the Cummins would be cool as well. Just a whole lot of work, and the six is different enough to be cool on its own.
11-08-2013, 12:52 AM | #3 |
which 5.9 cummins did you get?
What kind of mileage do you get with your current engine? Do you care about mileage? you can definatly make some big power with a cummins....but you better beef up your drivetrain. I'm getting about 17.5 mpg out of my 7000lb lifted 4x4 crew cab on 35s. I'm hoping to get 20 mpg by the time I'm done tinkering with it. |
11-08-2013, 01:26 AM | #4 |
I get 12mpg right now with the turbo six but should have no problem pulling 20 after some more tweaking with the carb some more. I would be running the oem transmission for the cummins, and the rearend in the truck is 12bolt with 3.07 gears eaton posi with 600lb springs and moser axles and the current driveshaft is out of a 3/4 ton so the driveline is good to go. I'm not so concerned about the power of the cummins either... stock it puts out 325 hp and 610ft lbs torque... and with the gearing I should easily pull 20+ in it with an egr delete, chip it for economy, propane injection, and 5" Mandrel bent exhaust
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 Last edited by longbed67; 11-08-2013 at 01:31 AM. |
11-08-2013, 01:34 AM | #5 |
Proprietor of Dale's Corner
I voted for the six because it's different. There's a lot of hot rod Cummins
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
11-08-2013, 01:39 AM | #6 |
I think it depends on what you want to do with it. Towing points towards the Cummins ISB. Cool factor? The nod goes toward the turbo.
My $.02........... |
11-08-2013, 01:54 AM | #7 |
The 5.9L got came from a 2006 3500 with 140000 on it and the trans.
11-08-2013, 02:34 AM | #8 |
There is nothing like the sound of a turbo diesel. I vote 5.9.
11-08-2013, 03:26 PM | #9 | |
6>8 Plugless........
To me, I'd say the cummins. That thing would be a blast with minimal mods! They aren't too bad stock. Tuned properly and you's be over 20mpg.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-08-2013, 04:08 PM | #10 | |
11-08-2013, 05:02 PM | #11 |
You didn't get to me. I see where you're coming from. He needs to build another truck so he'll have both.
11-08-2013, 05:44 PM | #12 |
I haven't voted, I can't make my mind up both setups are great!! You know just saying if you did go with the diesel it would make a great set of vehicles to find a first gen Chevy II or a Vega with that turbo 6 under the hood, that would be something different and cool.
11-08-2013, 06:15 PM | #13 |
I didn't think of that...I'll vote for that...always fun spendind other people's money..
11-08-2013, 07:21 PM | #14 | |
I think the 5.9L would be cool. You do know how loud that puppy is going to be (assuming you go with a straight through exhaust)?
Cheers - Wayne Our Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=620966 '55 Wagon Build - http://67-72chevytrucks.com/vboard/s...d.php?t=689157 1971 Cheyenne Super Ochre/White LWB 350 Auto - my son's truck "Nancy" 1972 GMC K2500 Custom 4X4 Olive LWB 400 SB 4-speed -"Greenie" - Restoration to begin after the '55 Nothing sucks more than that moment during an argument when you realize you're wrong. |
11-08-2013, 07:27 PM | #15 |
So, what would you do with the cummins if you do not put it in this truck? If you have no other project to put it in, you may have subconsciously already made up your mind. At least that's how it would have played out if it were me, lol
..........___ ..____//_{)] ______ [_(O)_[___][__(O)_] Project: Under Pressure II http://www.67-72chevytrucks.com/vboa...d.php?t=559720 |
11-08-2013, 08:57 PM | #16 |
I am a Referee of life.
I agree with the above.It's time for another truck.Build it with the Cummins and enjoy both.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
11-08-2013, 09:43 PM | #17 |
I'd stay with the turbo 250. It's different and beyond cool. I'm a diesel guy and I've owned a couple cummins 5.9 and they're bulletproof. If you wanted to do the swap it'd be an excellent choice engine wise. But personally I'd be more impressed by someone's truck with a turbo 250 over a cummins. Plus your going to add a wee bit o weight on the front end with that diesel. But it's your truck and there's not exactly a bad choice to be made. More power to ya either way.
G.R. 69 C-10 ol' rusty "If your dog doesn't like somebody, you shouldn't either." |
11-08-2013, 09:46 PM | #18 |
I agree with the sentiment, "you see plenty of hotrodded cummins running around"..They're all over the place in my neck of the woods,so my vote is keep the turbo-d 250...but hey, I'm partial to inline sixes.
If you aboslutely have to have a diesel go find another project to drop it in.
_____________________________________________ 69 C-20 292, 4 spd O/D, 4:56 rears. No a/c p/s p/b p/w......restoration project,"Operation:Stovebolt" 78 C-10 305 TH350 new (old) daily driver 02 Suburban Z71 a.k.a. the family truckster 99 Silverado 1500 Z71 |
11-08-2013, 11:47 PM | #19 |
Too many 6cyl Cummins around, not enough turbo inline sixes. Just my thoughts.
2005 GMC K2500HD D/A 1993 GMC K1500 2011 Subaru Legacy. 2013 Subaru Outback 1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot. |
11-09-2013, 01:26 AM | #20 |
Keep the six. Cummins are cool and have there place...usually in the rear view of my duramax. A solid trans even to hold a stock cummins motor reliably for many miles will cost you 5k. There is too many of these trucks these days being total custom they lose there original touches. Keep your truck how it is. Just my honest opinion
11-09-2013, 10:18 AM | #21 |
Winner winner chicken dinner!
I think your turbo I-6 is the coolest thing, so my vote is for keeping the Chevy motor in the Chevy truck...if you decide to just have one truck.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives |
11-09-2013, 11:32 AM | #22 |
11-09-2013, 12:17 PM | #23 |
Cummins! Diesel was the only fuel available after Superstorm Sandy here on Long Island!
I am looking for a truck, and would love to find a 67-72 Diesel, which are as rare as hens teeth. Bill |
11-09-2013, 03:32 PM | #24 |
I agree
11-10-2013, 12:26 AM | #25 |
I think I needed to add a 3rd option of build another truck.... Like a 4x4 crew cab with a cummins.... I think problem solved I'll keep this truck the way it is...for now...
