Old 11-08-2013, 12:05 AM   #1
CaliLivn
Not good door latch spins freely
My 72's passenger side door latch spins freely inside. The part that catches on the striker plate to hold the door shut. I can push the door in an lock it an it'll stay closed but if I don't lock it the door won't stay shut.... I'm thinking I need another latch or is there an adjustment or something? I haven't taken it off yet. I removed the door panels an noticed the window track in the way. I'm kinda handy but wanted to ask for some advice an help on here first before taking stuff apart.
CaliLivn is offline   Reply With Quote
Old 11-08-2013, 07:36 AM   #2
hugger6933
Re: Not good door latch spins freely
Yeah, you need a latch and you will be shocked at difference a new one makes. jim
hugger6933 is offline   Reply With Quote
Old 11-08-2013, 08:45 AM   #3
Sammy
After 40 plus years of faithful abuse it has finally given up. Surprised it is the passenger side usually the driver's side is first. Don't think you can expect that kind of dedicated service from your newer vehicles today.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 11-08-2013, 02:24 PM   #4
jhwkns
Registered Cruiser
jhwkns's Avatar
Same problem here. Passenger side is kaput as of yesterday. Heading out to pull it apart in a little while.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 11-08-2013, 11:16 PM   #5
brad_man_72
the boat guy
brad_man_72's Avatar
My drivers side did that not too long ago. I just had to weld the piece that broke back on, works good as new now.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 11-08-2013, 11:46 PM   #6
CaliLivn
How'd it go? I'm gonna pull mine when I get my replacement latch.
Old 11-09-2013, 12:09 AM   #7
Vova
I'll try to pull it tonight and bring it tomorrow.
Vova is offline   Reply With Quote
Old 11-09-2013, 12:14 AM   #8
Drewski23
what do you mean spins freely? Im just asking because i have my doors apart and im replacing everything inside..my doors open and close fine but i dont want to be taking my truck apart again after everything is finished...how do i know if they are going bad?
Drewski23 is offline   Reply With Quote
Old 11-09-2013, 12:28 AM   #9
CaliLivn
Thanks Vova. No biggie if u can't. It can be shipped later. I got cash for those other parts tomorrow.
Drewski23 I don't really know how to tell if their going bad? One day mine was working then the next day my pops opened the door an shut it an it wouldn't stay shut. The piece that catches on the striker plate just spun around an didn't engage.
Old 11-09-2013, 05:32 AM   #10
jhwkns
Registered Cruiser
jhwkns's Avatar
It was only the spring that broke on mine. I'll try to get a replacement tomorrow.
Old 11-10-2013, 12:07 PM   #11
Jurassic-1
Jurassic-1's Avatar
I have had the same problem. Sometimes they get a broken spring and others have worn out the catch lever. Another sign of a worn latch is the door popping back after it is shut. It will not always pop open just click back 1 notch.If you look at the gear wheel on the latch with the latch assy. removed you can see a latch finger that stops the wheel from turning freely. I have noticed considerable wear on some old trucks where they were never lubed. I have been able to weld the catch and reface it and it works like new. So if you are handy with a welder you may be able to repair it.
Jurassic-1 is offline   Reply With Quote
Old 04-08-2017, 10:02 PM   #12
JudgeUnderwoodHammer
My driver door latch messed up on me the other day. Rolled the window up and when I shut the door it popped back open. Latch just spun like mentioned above. When I came out to leave I grabbed a piece of wire to tie it shut. I rolled the window down to cool off while working on it and to my surprise it latched! Tried again with window up. Latch didn't work. Rolled the window down and boom...latched perfectly. I dunno whats up with it. Just thought I'd share.
JudgeUnderwoodHammer is offline   Reply With Quote
Old 04-10-2017, 01:46 AM   #13
El Dorado Jim
http://67-72chevytrucks.com/vboard/s...d.php?t=732400 here is a good thread on how to take your door apart to get the latch assembly out
El Dorado Jim is offline   Reply With Quote
