ignetion switch removal question
I am removing everything from the dash, of my 67 C10, so I can paint it. All is removed except the ignition switch. I cannot figure out how this thing goes together so I can take it out of the dash. Will someone please give instructions on how to take it out of the dash without destroying it? Thanks
#16876
Re: ignetion switch removal question
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
The actual switch unscrews from the chrome bezel on your dash
The Older Generation
Here is a writeup on the procedure to go along with the video… 67's and some 68's don't have an accessory position. Just put the key in the ignition and "gently" turn it as far to the left as it will go. Insert a straightened paper clip in the hole (the large ones work best) and push the release pin down (go easy here, it doesn't take much pressure at all) and turn the cylinder to the left a little more. As you turn the cylinder you have to remove the paper clip or it will bind in the hole. The cylinder should pull out. You should not have to force anything, but you might have to wiggle it a little. If you do not have a key the code number should be stamped on the door lock cylinder, (see pic below) sometimes one, sometimes both. The only time I have found one that didn't have the code stamped on it is when the lock had been replaced with a new one. Check the passenger door first. Generally the lock case will have to be cleaned very well to be able to see the code number. A small wire brush, steel wool, scotch bright, or sandpaper usually works well for this. I do not recommend a wire wheel because it will completely remove the code number if it is stamped lightly. The code number is always stamped into the lock case, never cast into it. Most locksmiths can cut a key from this code number. Home centers and hardware stores will not be able to do this. If the locks are original to the truck or were all replaced at the same time the key made from the code number on the door lock should fit the ignition switch & usually the glove box too (but not always). Here is a picture with the parts labeled and one that shows the location of the code number on the door lock cylinder... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-08-2013 at 07:29 PM. |
It sure makes a job much easier when you have great help from knowledge people. My switch came out of the dash in a matter of minutes. Thanks a lot!
#6 | |
Glad to hear you got it out OK. Some of them can be a little tougher than others. LockDoc
#7 | |
#16876
