11-08-2013, 01:36 AM | #1 |
Turn signal switch loose
The turn signal switch rod in my 68 has been loose ever since I got the truck back. It also does not click off after my turns are completed. Do I have to pull the steering wheel to replace it?
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
11-08-2013, 08:42 AM | #2 |
Re: Turn signal switch loose
Yes you will, it sounds like the switch broke.
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
11-08-2013, 10:48 AM | #3 |
Your canceling spring is broken, yes you have to remove the wheel.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
11-08-2013, 08:19 PM | #4 |
Rats! Do I need a steering wheel puller, or can this be done with a socket set?
11-08-2013, 08:46 PM | #5 |
You can remove it without a puller. Remove the nut on the wheel and remove the washer if there is one. Important put the nut back a few threads, this will stop the wheel from hitting you in the face. Give the wheel a few whacks with your hand on the backside, then pull real hard. It should come off.
11-09-2013, 07:50 PM | #6 |
Just got done replacing my turn signal switch a couple hours ago!
I accidentally pushed down on my turn signal too hard and broke the switch on the inside. I lost the turn signals, and it also caused one of my brake lights to not work, while the other one flickered. I ordered the switch from LMC, and it took me about an hour and a half to swap it out. The turn signal is much more "crisp" now, no play, binds, or noises. If your steering wheel is perfectly straight when you're going down the road, be sure and mark it before you take it off! They're sensitive to their position! There's a factory alignment mark on the column bolt, but mine was a little off true alignment. At first I had a hard time tucking the wires in, to where they weren't in the way. Then I had a Homer Simpson "DOH!" moment, when I saw the little hook on the switch that kept them out of the way. After that it was a breeze.
-Bruton 1968 GMC long bed 5.7/700R4 --I'd rather push a Chevy, than drive a Ford.-- |
11-09-2013, 08:03 PM | #7 |
Why did it take an hour and a half?!?!? I was hoping it would not be that involved! I hope this is not too complicated.
11-09-2013, 08:35 PM | #8 |
I had to stop a couple times, (the girlfriend needed help hanging pics.) it's not too involved, but more involved than you'd think. Just pay attention to how you take it all apart. If you need help give me a hollar.
